Author Topic: New car tomorrow hopefully!!!!, got it :)  (Read 3410 times)
Offline dub-gti
Re: New car tomorrow hopefully!!!!, got it :)
« Reply #20 on: 12 February 2012, 13:50 »
Drop it 40mm and enjoy it, don't slam it
says the man whos got a dropped mk3,
just do what you want to it, but dont buy cheap coilovers if you want to drop and retain some comfort,
cheap coilovers aren't that bad, they only ride hard when you drop them real low.
Offline tweed
« Reply #21 on: 12 February 2012, 14:22 »
I have a slow 8v gti dropped on it's arse and stanced out.
I also have a vr6 dropped 50 front 40 rear with a good set of coilovers. Has standard alloys and sticky yoko tyres  :wink:
Offline Shady Pioneer
  • graphic designer.
« Reply #22 on: 12 February 2012, 14:41 »
Good luck with it mate. Hope you check the sills for rust? You saw the state of my old valver right?
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #23 on: 12 February 2012, 15:33 »
nice move have some fun  :smiley: i will be keeping an eye on it  :smiley:
Offline murraymint
« Reply #24 on: 12 February 2012, 16:02 »
Cheers!
Yh I only want a 40mm drop as the roads round here are fairly twisty so want to have some fun init, what coilovers do you recommend? Can I get a good set for around £400?
Yh I saw your old valves shady didn't look good, I'm gunna remove the sills and arches soon but there's no rust/rust bubbles near the sills so fingers crossed there gunna be ok/ minimal rust.
What's the best way to remove the sills? I did a search but no luck.?
josh
Offline dom
  • Back in a Mk4
« Reply #25 on: 12 February 2012, 17:15 »
Cheers!
The outer covers just pull off (you have to remove the end cap inside the front wheel arch first), with the covers off there are just a few screws holding the inner sill cover to the sill :wink:
As for coilovers, £400 should get a decent set...Weitecs or something similar.
Offline murraymint
« Reply #26 on: 12 February 2012, 17:21 »
Cheers that my job for next weekend sorted then  :smiley:
Ideal, are these any good?
http://www.venommotorsport.com/manufacturer_product.php?manufacturer=FK&category=Suspension&product=SportEditionCoilovers
I had a set of fk streets on the 1.6 and they seems pritty good.
josh
Offline Li-D
« Reply #27 on: 14 February 2012, 12:02 »
For around 200 you could get a full suspension kit, I.e springs and shocks. And if you want the low look snd still retain good hamdling go for a 60mm drop. My mates.on that set up  and handles very well
Mk3 Golf TDI - GTD replica in progress....
OEM CHIPPED....
NO POKE WITHOUT SMOKE!
