Author Topic: Quick q  (Read 1959 times)
Offline jonrandom
Re: Quick q
« Reply #10 on: 08 February 2012, 06:27 »
This was from my agu and my one from the R32 didnt have the metal bit on the RHS.
My car is still being built in my garage so havent driven it, so havent felt the benfits yet mate.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Quick q
« Reply #11 on: 08 February 2012, 07:50 »
Mine was exactly the same as the mount I took off the car :huh:
Offline GunnerCP
Re: Quick q
« Reply #12 on: 08 February 2012, 10:39 »
Thats probably because yours is broken then and it's snapped off! The extra bracket should be there.....
Offline navmk4gti
Re: Quick q
« Reply #13 on: 08 February 2012, 12:39 »
The dsg one i have has the metal bit on end mate think yours is bust  :lipsrsealed:
Offline jonrandom
Re: Quick q
« Reply #14 on: 08 February 2012, 13:23 »
 :sad: well that's a fu*ker, it didn't look like anything had snapped off will have to check it.
Offline navmk4gti
Re: Quick q
« Reply #15 on: 08 February 2012, 13:36 »
You may be able to take it off your old one as looks like bolted on from bottom not sure tho
Offline jonrandom
Re: Quick q
« Reply #16 on: 08 February 2012, 15:12 »
From what i remember i couldn't take it off as i did look to do it pretty sure it was all attached to the bush will have check again
Offline jonnyturbo
Re: Quick q
« Reply #17 on: 08 February 2012, 15:16 »
The little metal plate comes off with the mount . I think all the little metal plates are the same right across the range of mk4 engines. Its just the bush and bush stiffness that differs
Offline navmk4gti
Re: Quick q
« Reply #18 on: 08 February 2012, 16:06 »
Yh ur ryt it is on just by the bush should be able change it easily then as you can buy bushes for that seperate
Offline jonrandom
Re: Quick q
« Reply #19 on: 08 February 2012, 17:54 »
Nice will look in to it  :smiley:
