Author Topic: AEH 1.6 8v Head Bolt Torque Settings and Tightening Sequence. HELP!!!!  (Read 7640 times)
Offline richw911
I am sure you need to use new bolts as well.  :smiley:
Yep because they are stretch bolts.
Guess they would be, also make sure you blow the bolt holes out as anything left in could mean the block cracking.
Offline greenhornetgti
Thanks for you replys, the torque settings and sequence are exactly what i needed. i have bought a new set of head bolts, thermostat, and gasket set so hopefully it will a go smoothly.
