Author Topic: Agu decat  (Read 3840 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Agu decat
« Reply #20 on: 07 February 2012, 22:12 »
Where it joins together in the middle just use paste like Chris said, you'll just need a gasket to join to the turbo
Offline navmk4gti
Re: Agu decat
« Reply #21 on: 07 February 2012, 22:24 »
yh mate i need pic for gasket onto turbo .. theres 4 hole on eand 3 not sure agu one is i dont want dealers fook it up like they have in past this stuff  :grin:
Offline navmk4gti
Re: Agu decat
« Reply #22 on: 07 February 2012, 23:42 »
Ny1 need it tonyt before head dealers morning
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Agu decat
« Reply #23 on: 08 February 2012, 07:48 »
It's the 4 hole gasket you need
Offline navmk4gti
Re: Agu decat
« Reply #24 on: 09 February 2012, 13:47 »
Right this what got from dealers it dot look right at all as i thought. Took me hour of them searching as they said is no gasket then came
Up with these>>>>
One gasket is tiny the 4 hole one looks right can someone shed some light on this and the bolts and nuts look odd too  :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Agu decat
« Reply #25 on: 09 February 2012, 13:52 »
your dealers are rubbish...
The gasket in the first pic is for the turbo to manifold which you don't need. They have also given you turbo exhaust studs, you may need them though as they can snap. But you'll only ever need four lol. The nuts are right albeit too many (again you only need four)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Agu decat
« Reply #26 on: 09 February 2012, 13:55 »
Also there is no dealer part for the join in the decat, on the standard pipe this is one piece. Just use some paste on that joint and 3 random nut/bolt combination. Try not to use nylocs though as they could get too hot and melt
Offline rio_gti
Re: Agu decat
« Reply #27 on: 09 February 2012, 13:58 »
the bolt/studs- you use 4 they go into the turbo (where the exhaust butts up to) thats if you are removing the old studs when you remove old nuts to remove old dp (one of mine snapped when i removed mine so good you got new ones just in case)
gasket with 4 holes - this goes between dp and turbo (slips onto bolt/studs that stick out the turbo)
nuts - after putting dp onto turbo, tighten nuts to hold it on!!!!
3 hole gasket - might fit between both pieces of the dp
Offline navmk4gti
Re: Agu decat
« Reply #28 on: 09 February 2012, 15:13 »
There more then rubbish they dont know fook all :angry:
Yh the small one is supose go between cat and downpipe but its so small doesnt look like it is going to fit. Will i need any bolts or screws to put decat and downpipe together or just that sealent you on about and use bracket hanger from old cat downpipe connection :undecided: Im not going to fit it chris is going to do it just wana make sure have evrything for the job on tuesday :smiley:
Offline Chris.
Re: Agu decat
« Reply #29 on: 09 February 2012, 15:20 »
Am i?  lol :D
Click For Build Thread
