Author Topic: Engine just blew up... no it didn't... (it was the gearbox)  (Read 2192 times)
Offline GTI JIMMER
Re: Engine just blew up... or so i thought...
« Reply #10 on: 03 February 2012, 12:37 »
Two pictures of what appears to be the source of the leak...
Another picture of behind the engine, looks like another separate leak?
http://i1214.photobucket.com/albums/cc485/jimmycobz/photo-2.jpg
http://i1214.photobucket.com/albums/cc485/jimmycobz/photo-1.jpg
http://i1214.photobucket.com/albums/cc485/jimmycobz/photo.jpg
(sorry about having to send link instead of uploading the pictures, the img codes don't seem to want to work)
« Last Edit: 03 February 2012, 12:48 by GTI JIMMER »
Offline Khare
  • The bear that khares
« Reply #11 on: 03 February 2012, 12:47 »
Can't see much from that picture, but if you managed to start it up again and it sounded just a bit tappety and idles then it won't be a rod. As tweed said you probably broke the sump. However the fact that you've started it afterwards and let it idle (however long it was) makes me think you've completely ruined any chance of saving that engine.
Offline MK3 Menace
  • 98 GTI, big changes are coming...
« Reply #12 on: 03 February 2012, 12:48 »
Thats the crankcase breather, sure its come from there?
Does the breather still have the metal horseshoe clip holding it in?
Have you checked all underneather for leaks?
Was it freezing where you were last night? Any anti freeze in it?
Sorry for so many questions, I had similar and it was the previous owner only half threading the sump bolt...
Offline GTI JIMMER
« Reply #13 on: 03 February 2012, 12:53 »
 :sad: fair enough  :sad:
Seems to be coming from that... or in the crevice just behind that?  the metal clip is still in there, and yeah it was really cold, must have been below 0 degrees, but had no problems in the cold before, yeah there is anti freeze.
Will have a better look tomorrow, cheers guys.
Offline tweed
« Reply #14 on: 03 February 2012, 15:03 »
Check the oil level. Put oil in and start the engine, then look for leaks
Offline CJA321
« Reply #15 on: 03 February 2012, 15:07 »
Thats hardly a leak... if youve lost all your all the will be a huge mess, no just a drip  :tongue:
Offline danny_p
« Reply #16 on: 04 February 2012, 11:44 »
if there was a bang,  all the oil left and it started ratteling it sounds like a ROD left the building.
they don't allways punch gaping big holes in block but can snap the intermediate shaft and or just crack the block or sump.
and they'll drive when blown up.   i drove a 16v  4 miles  on 3 cyls after a rod went out through the side, it took the oil pump, intermediate shaft and all the oil with it as well.   it even was shunted around on the drive under its own power till k took the motor out
all the VW's have gone bar 1.
billabong
« Reply #17 on: 04 February 2012, 12:30 »
Does your engine run?
I thought my head gasket had gone but it was my gearbox...pissed oil everywhere (smells like rat pish).
If the oil is dark though its probably the engine...
Offline GTI JIMMER
« Reply #18 on: 04 February 2012, 13:28 »
This is what happened :embarassed: :grin:
Going to see what the garage say, but it wasn't engine oil, it was gearbox oil  :embarassed:
It's probably going to need a new gearbox,  garage is a 10 second drive, going to take it there... Going to be a lot cheaper if i can get a fairly cheap gearbox on here... (might put an ad up in the next couple days)
(Sorry for the completely inaccurate title to start with)
« Last Edit: 04 February 2012, 13:31 by GTI JIMMER »
