Author Topic: wich antifreeze?  (Read 7768 times)
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: wich antifreeze?
« Reply #10 on: 02 February 2012, 17:27 »
Use g12 and mix before pouring in.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline Lewy
« Reply #11 on: 02 February 2012, 17:32 »
any antifreeze? i thought you had to use the propper stuff thats red? as using the wrong stuff can be bad for the system.
Don't be daft, any coolant that drops the freezing temperature will do.  The vehicles I work on have intergalactic mileage with no signs of water corrosion, and they are all using a generic ethylene glycol 50:50 mix.
jockgti
« Reply #12 on: 02 February 2012, 18:00 »
g12 is about 8 quid for 2 ltr when i bought it over a month ago
Offline richw911
« Reply #13 on: 02 February 2012, 18:35 »
ah ok apologies op  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 02 February 2012, 20:11 »
Lewy I know what you're saying but G12 is the only recommended stuff to use for some reason...
Offline Lewy
« Reply #15 on: 02 February 2012, 20:45 »
And who recommends it, VW?
Offline richw911
« Reply #16 on: 02 February 2012, 21:10 »
As you say probably a money making exercise but for the price of it ive never bothered using anything else  :smiley:
Offline cullygti
« Reply #17 on: 02 February 2012, 21:18 »
anti freeze is anti freeze isnt it never bothered using anything specific just as long as it withholds below a certain temp it should be fine wether it 99p or £100 all does the same job as far as i know  :grin:
Offline blade4real2004
  • golf gti with a touch of .:R
« Reply #18 on: 03 February 2012, 11:44 »
g12 contains an oil and rust inhibitors as well as anti freeze and dont mix differance colour anti freezes as they chemically react with each other and sludge up the rad and you will in the long run end up with over heating problems vw recommend g12 for a reason you can by g12 from most factors  g12 is just the type term for that type coolant as long as its g12 its fine for your vw other types of coolant one have the right blends or even have anything other then antifreeze in it
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline Lewy
« Reply #19 on: 03 February 2012, 11:56 »
G12 contains oils and a corrosion inhibitor?  Look up ethylene glycol and see what it contains....
VW recommend it, because they sell it.
