Author Topic: Martz Super Blue 8v  (Read 108123 times)
Offline Shady Pioneer
  • graphic designer.
Re: Martz Super Blue 8v
« Reply #160 on: 20 April 2012, 23:49 »
I think they should stay like that.  :cool:
Nice meeting you the other day mate. Hope you had a safe trip home.
Offline JC
  • Back in the North.
« Reply #161 on: 21 April 2012, 01:01 »
Filled her up today, £65 lighter now. Also increased it's value by 50%. :grin:
sweet, i will buy for £2oo if my g60s are included on collection  :kiss:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #162 on: 21 April 2012, 01:46 »
100% IMO  :evil:
For More Info Click To See;
Offline Martz
« Reply #163 on: 23 April 2012, 22:19 »
Cheers Shady, likewise.
Today she had a good ol' service and a few other little bits sorted out. All done before MOT time so no suprises will appear. Still not a fan of MK3's but this one is a good un! Looks like it will be about for a while. :smiley:
Question .......... Will a MK2 tinkered engine such as that that TSR build in a 8v form slot straight in and plug and play with the excisting loom? :huh:
« Reply #164 on: 23 April 2012, 23:46 »
Not really tbh, depends on base engine but block can be different in terms of breather layout etc.
Offline Martz
« Reply #165 on: 24 April 2012, 21:31 »
So, what would be involved with a ABF conversion?  DH perhaps could guide?
« Reply #166 on: 24 April 2012, 21:38 »
ABF would be very easy tbh, engine loom and ecu would be all that you really need.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #167 on: 24 April 2012, 22:02 »
Really easy to do in a day
donor engine, gearbox and flywheel including clutch etc (could use 8v box but i wouldn't), engine loom, loom from ECU to fusebox, ECU,
Hydro bits for the clutch and gearbox and gear linkages
Transponder and chip from donor cars key
Clocks if u want, (8v clocks will work tho)
Your mk3 is late spec so your pedal box has all provisions for the Hydro parts etc as does your brake fluid reservoir
rear drivers side mount is different on ABF cars although 8v would work ok
all plug and play..  but not much gain TBH..
« Last Edit: 24 April 2012, 22:03 by F17BAD »
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Martz
« Reply #168 on: 24 April 2012, 22:26 »
So alot of work for not much then?  If thats the case I won't bother. :smiley:
Really need a MK2 in my life again!
Offline F17BAD
« Reply #169 on: 24 April 2012, 22:43 »
yeah u would be better off putting the ABF into mk2 IMO
