Author Topic: EuroCarParts.... or Not??  (Read 8096 times)
Offline EuroCarParts
  • The UK's Largest Parts Supplier
Re: EuroCarParts.... or Not??
« Reply #20 on: 01 February 2012, 09:04 »
FYI
The part above (ZEF561) is equivalent to the below:
TDC Ignition Leads
Part No.: 409445030
Web Price: £20.70
http://www.eurocarparts.com/search/409445030/p/home
Patrick
Notice the coil lead has 90Degree bends on both ends. Will these fit ok, as the ones on my car now (probably original) has a 90Degree bend on the coil and a straight on the dizzy. hmmm....
Cheers  :undecided:
Hi mate,
The only other option we have to the one above is –
Part no.: 409445300
Web price: £21.90
Forum price: £16.42
http://www.eurocarparts.com/search/409445300/p/home
Specifications
Quote
Ø 7 mm, Copper, Silicone, Coupling Type M4, Coupling Type Saw Tooth, Coupling Type Saw Tooth, Length 1 390 mm, Length 2 490 mm, Length 3 550 mm, Length 4 610 mm, Length 5 690 mm
HTH
Kunal
« Last Edit: 01 February 2012, 09:08 by EuroCarParts »
