Author Topic: Temperature problem  (Read 1260 times)
Offline Ducco
Temperature problem
« on: 29 January 2012, 00:11 »
Hi, and an issue whit my temperature guage. First i suspected the temp sender was broken so i did get a new one, but same problem. The needle go's right to the top right away, even whit the wire unplugged from the sender. And the red light blinks but not all the time. As read some post on this. Any ground points to check?
Offline Roverdose
  • So long and thanks for all the fish!
Re: Temperature problem
« Reply #1 on: 31 January 2012, 17:15 »
try different clocks. also, does the oil temperature on your mfa work?
