Author Topic: GearBox chewer  (Read 1994 times)
Offline nukezz
Re: GearBox chewer
« Reply #10 on: 28 January 2012, 10:15 »
how many times u done the box :smiley:
twice and i think the third one is on its way  :cry:
Offline nukezz
Re: GearBox chewer
« Reply #11 on: 28 January 2012, 10:18 »
What are the symptoms of the failures?
Are you confident they have been the correct gearboxes for that engine type?  Silly question - Is it possible the lower spec might have been fitted?
I'd also consider the flywheel as a potential cause.  It could be sending judder/vibrations through the input shaft of the box.
when u put the foot down then once u let it off it makes a knocking noise from drivers side.
on the passanger side it vibrates above 60. ( not a loose whell or egg in tyre nor is it un-ballanced although may be susension)
jacked up front end and spun the wheels to discover a metal rubbing and banging noise  :undecided:
Offline harlemex
Re: GearBox chewer
« Reply #12 on: 28 January 2012, 15:21 »
are you positive its not an egg in the tyre?
