Author Topic: egay cai  (Read 4241 times)
Offline ginga
Re: egay cai
« Reply #10 on: 27 January 2012, 21:36 »
Can I also ask what's it done for your mpg
Offline james2
  • No scammers please.
Re: egay cai
« Reply #11 on: 27 January 2012, 23:30 »
its a french JR filter cc-07003B .Best mpg i got out of my AGU on motor way was 36+ at 80-110mph ,£40 lasted 213 miles until fuel light came on. Its the sound and extra power i like. It sounds very grunty on full boost (like a nice exhaust)and load DV noise .Lot of people knock it on here and say panel filters are better, all i can say is try it first. I try everything until i find the best for my car. But this is a copy of a £200+ cold air system (i wanted a pipercross vis).  :undecided: but for only £50 its a bargin. £30 for cai kit off ebay ,chop it down and i got a second hand JR filter for £20 off ebay.  :smiley: The JR filter should be:
 one rated up to 250 bhp .The filter i had to use was off set by 20 degrees ,120mm -100mm wide and 140mm long and it has a open end on the filter, and got a 70mm coupling silicon pipe (demonmotorsport)£9.
put a big cold air feed to filter by horn:
« Last Edit: 27 January 2012, 23:41 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james2
Re: egay cai
« Reply #12 on: 27 January 2012, 23:31 »
I tried one on mine and it would not fit due to the horns  :sad: but they are a worthwhile mod with a better filter.
i removed one of the horns
+1 .one of mine died .You only need one for mot .Save a tiny bit of weight. :smiley:
Offline Darksider1.8T
Re: egay cai
« Reply #13 on: 28 January 2012, 08:55 »
you do no water runs down there when it rains?
Re: egay cai
« Reply #14 on: 28 January 2012, 12:56 »
no mate the filter is to stop debris not water.
Re: egay cai
« Reply #15 on: 28 January 2012, 14:23 »
i give up!
Offline james2
Re: egay cai
« Reply #16 on: 28 January 2012, 22:39 »
If its in your arch i wouldnt trust it, been through big puddles.Mine has oil spray on it /water runs off. As above dont drive through a lake or a river and you will be fine. One bloke at work somehow seizzed a merc sprinter van ,aa got the water out but he bent the rods, god know how he did it. Most of tryed crossing a lake.  :smug:
Offline golf-sib
  • Турботазик
Re: egay cai
« Reply #17 on: 28 January 2012, 23:31 »
mines by horn. + lower than alot of the pussys on here and drive everyday. no problem unleas its SUBMERGED kapiche?
+1 :afro:
Also real men seal the hole in the filter box to let the engine drink real water.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
