Author Topic: AUQ and AUM...... Differences between them.  (Read 3905 times)
Offline bosco
« on: 26 January 2012, 13:23 »
Ok been looking at a few different options for my turbo build and have decided im going to rebuild a different 1.8T with rods, shells etc etc but wanted to use all my other stuff off my AUQ that I have at the moment.
Can I say just buy a second hand head,block, sump from a different code1.8T and transfer all the ancillaries from my AUQ over onto it or are there all different connections or anything?
Hopefully that makes sense
Thanks guys
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Offline bosco
Re: AUQ and AUM...... Differences between them.
« Reply #1 on: 28 January 2012, 21:56 »
Anyone?
1990 mk2 1.6 daily
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 29 January 2012, 00:49 »
There are a few differences with the way the pipes are laid out on the PCV system but I can't see there being a lot else...
Offline bosco
« Reply #3 on: 29 January 2012, 10:25 »
Cheers man. Do you know is there many differences between the AGU and AUQ head?
1990 mk2 1.6 daily
Offline johnnyvr6
  • golf v6 4motion soon to be 1.8t'd
« Reply #4 on: 29 January 2012, 10:41 »
agu is meant to be the strongest engine for big bhp
Offline bosco
« Reply #5 on: 29 January 2012, 11:01 »
Cool are there many physical differences between the AGU an AUQ heads? apart from vvt
1990 mk2 1.6 daily
Offline Chris#101
« Reply #6 on: 29 January 2012, 11:03 »
AUQ has VVT not sure about the other
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline brianpologti
« Reply #7 on: 29 January 2012, 11:54 »
Aqu small port  ko3s think 19mm wrist pins has vvt and map sensor,sap,and crappy clips on rear charge pipe.
 agu big port ko3 20mm , none of that crap.and alot better charge pipe.
I think aqu/aum are easier/better to map
I am running a ko3s agu. Daily
And an aqu with agu wrist pins/con rods and aftermarket bolts,agu rear charge pipe.
I think the different between aum and aqu is the ecu and some breather pipes, but unsure as it's only what I read.
Hope that helps
Oh and the aqu runs a n75f valve as standard(or e if it's been updated)
« Last Edit: 29 January 2012, 12:00 by brianpologti »
