Author Topic: 256mm rear brake setup  (Read 3936 times)
Offline Steve_PD
Re: 256mm rear brake setup
« Reply #10 on: 24 January 2012, 19:16 »
V5 isn't 4wd :wink:
its 6mm spacers to go between the calliper and the carriers, only for 256mm brakes off 4wd models
Spacer
Spacer fitted between calliper and carrier
Offline bobbarley
  • I'm kind of a big deal...
« Reply #11 on: 24 January 2012, 19:20 »
Just gotta go one better haven't ya?!  :grin:
Offline dilbert
« Reply #12 on: 24 January 2012, 19:31 »
As said no you dont need any spacers - you only need spacers if the 256mm rear brakes came from TT  / 4WD MK4.
sweet, cheers for that
mk4 golf 1.8 gti 20v
Offline dilbert
« Reply #13 on: 24 January 2012, 19:33 »
cheers for all the reply you lot, very helpfull, why isit the 4wd carriers are different ? are they spaced different because they run different hubs or something  ?
Offline richw911
« Reply #14 on: 24 January 2012, 19:34 »
Yeah because of the 4WD hub  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 24 January 2012, 21:38 »
don't forget to either change your splash guards or grind the lips off the ones you have now :wink:
Offline richw911
« Reply #16 on: 24 January 2012, 21:38 »
Time for yours soon?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 25 January 2012, 12:34 »
Yes mate, just finishing stripping down the calipers for a lick of paint then i'll book some time in DH & Mikes man shed to pull the rear beam off :afro:
Offline richw911
« Reply #18 on: 25 January 2012, 14:28 »
:afro:  :cool:
