Author Topic: Gearbox or Clutch foobarred after remap?! UPDATE  (Read 6352 times)
Offline mk3tony
Re: Gearbox or Clutch foobarred after remap?!
« Reply #30 on: 24 January 2012, 21:44 »
so update..
Got a call saying clutch is all fitted. ECS Stage 1, turns out the clutch plate had split in 2! they showed me in and said that would be why i was having trouble! The clutch itself wasnt actually that worn but at least thats all changed now. Single Mass conversion with 14lb flywheel.
BUT, go to start it and see smoke coming from bay, starter motors fried. So once again I am left car less! WHEN WILL IT END  :cry:
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline richw911
« Reply #31 on: 24 January 2012, 21:46 »
so update..
It wont /  it doesn't  :kiss:
Offline topher
  • Administrator
  • fully functioning
Re: Gearbox or Clutch foobarred after remap?! UPDATE
« Reply #32 on: 24 January 2012, 21:47 »
if that was the first turn of the key since the gearbox got bolted back on, check the flywheel isn't jammed
Offline richw911
« Reply #33 on: 24 January 2012, 21:50 »
Good point !
Offline mk3tony
« Reply #34 on: 24 January 2012, 21:51 »
how would you know? They took the starter motor out because I was there and put a live onto it and the piston went up but the cog didnt turn so they're getting a new starter motor tomorrow
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #35 on: 25 January 2012, 12:37 »
Turn the engine over by hand via the bottom pulley on the cam belt end and see if it turns. Take the plugs out to make it easier too
Offline mk3tony
« Reply #36 on: 05 February 2012, 22:56 »
So an update, new starter motor and all is fine bar some maf issues :angry:.
Anyway 1st and 3rd aren't engaging properly. Its not all the time, but most, you move it up, it sort of goes 3/4 the way and then stops. Press clutch down, release and try again and it goes in fine. Air in the system, slave/master cylinder or gearbox? :cry:
« Last Edit: 06 February 2012, 00:27 by mk3tony »
Offline mk3tony
« Reply #37 on: 06 February 2012, 20:17 »
anyone got any suggestions?
Offline harlemex
« Reply #38 on: 06 February 2012, 23:03 »
you might need to re adjust the linkages.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #39 on: 06 February 2012, 23:05 »
Did you have the clutch bled?
