Author Topic: Gearbox or Clutch foobarred after remap?! UPDATE  (Read 6353 times)
Offline thatwillis
Re: Gearbox or Clutch foobarred after remap?!
« Reply #20 on: 22 January 2012, 14:37 »
I had problems engaging 1st and 2nd gear and eventually they went all together. It is a common ish problem with the MK4 boxes. It's the selector fork for 1st and 2nd that goes meaning you can no longer select them gears. Do a google search on MK4 golf gear selector problem. Mine ended up costing me £800 as driving home in 3rd, from where the gears went, meant the clutch was fooked as well. I suggest doing a little research and see if what other people have experienced is what happened with yours then maybe get a gearbox specialist to have a look at it. They have to remove the box to do the clutch so it'll probably be worth doing that as well if it comes to it.
 :angry: My 1st and 2nd gears have been gettig stiff to get into  :cry:
Offline mk3tony
« Reply #21 on: 22 January 2012, 14:54 »
reverse is an arse to get into and when cold getting into 2nd was just a little grindy, i'll get the clutch done and then see what happens
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #22 on: 22 January 2012, 15:01 »
i had problems getting first from cold,and a notchy feel in both 1st and 2nd,for about a year-3 different garage's told me there was nothing wrong with it,just kept lubing up the linkage.eventualy,i had the gear box oil checked,and hey presto,it had a hint of cooper/bronze in the oil,which meant there was damage in the box.i was lucky,and found a low (lower than mime!) milage box for £110 and it's like new.
hope ya get it sorted,must be murder not being able to use your newly mapped motor?!!  :angry:
Can you lube the linkages yourself, and what would you use to this with? Also can you 'check' the gear box oil as well & or change it your self?
Offline mk3tony
« Reply #23 on: 22 January 2012, 15:04 »
check the how to section scarr, theres a thread on changing the gear box oil i'm sure  :wink:
Offline thatwillis
« Reply #24 on: 22 January 2012, 15:52 »
I heard something a while ago about just ajusting the gear linkage? Someone correct me if i'm wrong.
http://www.youtube.com/watch?v=tp9ggefOjAE
Offline scarr89
« Reply #25 on: 22 January 2012, 16:00 »
I think some one mentioned that isn't the reason why you get clunky gears. However it may help if you do this.
Offline mk3tony
« Reply #26 on: 22 January 2012, 16:05 »
it will still be the first thing i do once new clutch is in!
Offline scarr89
« Reply #27 on: 22 January 2012, 16:24 »
Found it, but with no pictures  :undecided: :sad:
Are the boxes on the DERV the same as petrols? I have a GTTDI see and would very much like to do this but am wondering if the guides would be different... :huh:
Offline mk3tony
« Reply #28 on: 23 January 2012, 23:43 »
So I took the car for a little drive, after a spirited trip all I could smell was clutch, is this a goodsign as in it would indicate clutch and nor gearbox?!
Offline harlemex
« Reply #29 on: 24 January 2012, 13:32 »
yes as long as it was clutch you could smell and not molten gearbox parts  :shocked:
