Author Topic: Gearbox or Clutch foobarred after remap?! UPDATE  (Read 6354 times)
Offline james2
  • No scammers please.
Re: Gearbox or Clutch foobarred after remap?!
« Reply #10 on: 20 January 2012, 23:58 »
My moneys on the clutch needs changing.  :wink: I had this on a different car the next morning it wouldnt go in first gear.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
« Reply #11 on: 21 January 2012, 00:01 »
yes a map will kill the clutch quicker due to the extra power its been putting through it
Not always the case  :smiley: driven carefully it should not shorten its life unless it was in poor health before.
Offline mk3tony
« Reply #12 on: 21 January 2012, 00:11 »
never mind your clutch what figures did you make mate haha  :laugh:  :laugh: r-tech ftw  :cool:
stock:
153 bhp and 159 lb/ft
mapped
209bhp and 237lb/ft  :cool:
i think i'll get the clutch done anyway and go from there. wont be driving the car for a few days now :( this is torture!
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline mk3tony
« Reply #13 on: 21 January 2012, 00:16 »
if gears are hard to select   its suggests the clutch isn't disengadeing fully,  its hydralic you chould allways bleed it before  pronounceing the clutch or box dead.  just as likely a leacky / worn  master or slave cyl
just recently has gearbox oil changed to see if it would help so they were all checked as had service at the same time
Offline topher
  • Administrator
  • fully functioning
« Reply #14 on: 21 January 2012, 02:09 »
bleeding the clutch is not the same as gearbox fluid..
Offline mk3tony
« Reply #15 on: 21 January 2012, 16:30 »
No but clutch fluid was checked. Either way I need a new clutch to cope with power so i'll do that first then go from there  :smiley:
Offline barrym381
« Reply #16 on: 21 January 2012, 17:03 »
still doesnt rule out air in it :smiley:
Offline mowlamb
  • MK4 GT TDI 130 - DERV POWER!!
« Reply #17 on: 21 January 2012, 19:11 »
I had problems engaging 1st and 2nd gear and eventually they went all together. It is a common ish problem with the MK4 boxes. It's the selector fork for 1st and 2nd that goes meaning you can no longer select them gears. Do a google search on MK4 golf gear selector problem. Mine ended up costing me £800 as driving home in 3rd, from where the gears went, meant the clutch was fooked as well. I suggest doing a little research and see if what other people have experienced is what happened with yours then maybe get a gearbox specialist to have a look at it. They have to remove the box to do the clutch so it'll probably be worth doing that as well if it comes to it.
The vid that was posted maybe the same one I saw regarding resetting the gear linkages manually and it is worth a try but it didn't work in my case. Google search may help you determine what could be the cause and help you decide how to go about it.
Offline mk3tony
« Reply #18 on: 21 January 2012, 21:49 »
It was all gears, doesnt engage gears properly. Spoke to a specialisy and they said sounds like clutc. I've ordered ecs stage 1 kit with lighter flywheel and should get fitted tuesday so will go from there!
Offline wessexgti
« Reply #19 on: 22 January 2012, 13:07 »
i had problems getting first from cold,and a notchy feel in both 1st and 2nd,for about a year-3 different garage's told me there was nothing wrong with it,just kept lubing up the linkage.eventualy,i had the gear box oil checked,and hey presto,it had a hint of cooper/bronze in the oil,which meant there was damage in the box.i was lucky,and found a low (lower than mime!) milage box for £110 and it's like new.
hope ya get it sorted,must be murder not being able to use your newly mapped motor?!!  :angry:
