Author Topic: Gearbox or Clutch foobarred after remap?! UPDATE  (Read 6350 times)
Offline mk3tony
« on: 20 January 2012, 21:18 »
Evening all,
Just on my way back from remap (Thanks Rtech :cool:) and after 3 hours of being stuck in traffic I needed to stop for petrol. So fill up, pay, start up and head off. Suddenly its hard to engage gears, they'll eventually go in but sometimes they'll miss completely. So I take it easy and get her home. Is the remap prematurely killing the clutch or the gearbox?!
« Last Edit: 24 January 2012, 21:44 by mk3tony »
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline mcgee9t2
Re: Gearbox or Clutch foobarred after remap?!
« Reply #1 on: 20 January 2012, 21:25 »
could just be something like this
http://www.youtube.com/watch?v=tp9ggefOjAE
cant see it being clutch unless you can feel the clutch slipping
Offline mk3tony
« Reply #2 on: 20 January 2012, 21:52 »
forgot to say it was slipping. it was only like this after remap. Before remap there was a spongey feel at the bottom of pedal travel so i suspected the clutch needed replacing soon but wondering if the remap has just killed it quicker?
Offline mcgee9t2
« Reply #3 on: 20 January 2012, 22:04 »
yes a map will kill the clutch quicker due to the extra power its been putting through it, and i suspect you had a play will all that extra power on the way back :evil:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #4 on: 20 January 2012, 22:09 »
So if it takes a bit 'force' to get your car into 1st and 2nd, which mine does (only on first and 2nd), and you can feel almost like a 'crunch' when getting in gear if you do what this vid does could that cure that issue?
Thanks  :smiley:
Offline mk3tony
« Reply #5 on: 20 January 2012, 22:12 »
damp road, remap test drive = wheel spin in third :cool: the gearbox wouldnt be a cause would it as i don't want to buy a new clutch and have it fitted to still have the same issues. I know the symptoms was a slipping clutch but difficult to engage gears? It was clunky when getting into all gears before but this is completely different
Offline johnnyvr6
  • golf v6 4motion soon to be 1.8t'd
« Reply #6 on: 20 January 2012, 22:24 »
My vr6 was like that and it turned out to be the gear linkage
Offline mk3tony
« Reply #7 on: 20 January 2012, 22:39 »
correct me if i'm wrong but isnt the linkage on a vr6 rods and on mine cable? would it get worse after a remap?
« Last Edit: 20 January 2012, 22:43 by mk3tony »
Offline cullygti
« Reply #8 on: 20 January 2012, 23:24 »
never mind your clutch what figures did you make mate haha  :laugh:  :laugh: r-tech ftw  :cool:
Offline danny_p
« Reply #9 on: 20 January 2012, 23:45 »
if gears are hard to select   its suggests the clutch isn't disengadeing fully,  its hydralic you chould allways bleed it before  pronounceing the clutch or box dead.  just as likely a leacky / worn  master or slave cyl
all the VW's have gone bar 1.
