Author Topic: Spacers and wheel bolts  (Read 1888 times)
Offline stainesy
Re: Spacers and wheel bolts
« Reply #10 on: 20 January 2012, 16:01 »
M14 x 1.5
Standard bolts are 27mm so 35mm bolts will do fine
saying that though even without the spacer only realy get about 4 turns of the bolt. should i get 40mm ones to be safe? am going to fit a 10mm spacer on one side at the rear to even it out. should i use 40mm bolts for that?
« Last Edit: 20 January 2012, 16:03 by stainesy »
Offline Steve_PD
« Reply #11 on: 20 January 2012, 16:15 »
40mm for 10mm spacer
and 35mm for 5mm spacer
Offline stainesy
« Reply #12 on: 20 January 2012, 16:20 »
ok sweet so these are the ones for the front with 5mm spacers then? i no they are but want to make sure before i click buy.
http://www.ebay.co.uk/itm/370266515287?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
« Reply #13 on: 20 January 2012, 16:35 »
Wrong fit, you need taper for aftermarket alloys
Offline stainesy
« Reply #14 on: 20 January 2012, 16:40 »
NOOOOOOOOOOOO :cry: i just bought and payed for them.
the ones on the car now are lik that. and the wheel holes are rounded inside.
Offline stainesy
« Reply #15 on: 20 January 2012, 17:00 »
this is my wheel bolt hole and a original wheel bolt in. they seem to fit perfect.
is that tapered?
or are they ok?
« Reply #16 on: 21 January 2012, 09:08 »
Hard to see from the photo but aftermarket alloys normally use taper fit bolts, I think your using the wrong bolts.
Is it 100% that the bolts holes are rounded, might be worth checking with a straight edge.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 21 January 2012, 09:13 »
also don't be fooled into thinking having more thread poking through the back makes the bolt stronger, it doesn't  :wink:
