Author Topic: car stalling/cutting out  (Read 1348 times)
Offline km
« on: 16 January 2012, 19:48 »
the revs drop and the car cuts out, usually when i'm coming to a junction. also tries to stall when i pull off, sometimes miss fires.
also experiencing "bouncy idle" as explained in this post - http://www.golfgtiforum.co.uk/index.php?topic=218741.0
i've taken the tb off and cleaned it, but no change. i've had a new maf just under a year ago from vw.
It's an agu if that helps. i've scanned for fault codes.
http://wiki.ross-tech.com/wiki/index.php/00575  00575 - Intake Manifold Pressure
http://wiki.ross-tech.com/wiki/index.php/00561  00561 - Mixture Adaptation
i've also noticed that since winter has arrived, it's gotten worse. the car is shocking in the morning. most of the problems above fade away as the car is warmed up and driven a fair bit. something tells me i need to replace the ignition amp. any help? thanks.
Offline km
Re: car stalling/cutting out
« Reply #1 on: 17 January 2012, 14:54 »
anyone?
Offline daz veedub
  • Operation 1.8t bolf
« Reply #2 on: 17 January 2012, 14:56 »
Possible Causes
    Hoses incorrect connected, disconnected, blocked or leaking
    Pressure Unit for Turbo Charger defective
    Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
    Check Hoses
    Check Pressure Unit for Turbo Charger
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check Basic Setting > MVB 011
Possible Symptoms
    Engine Jolting
    Increased Fuel Consumption
    Poor Idling/Jolting
    Reduced Boost Pressure
Possible Causes
    Mass Air Flow Sensor (G70) faulty
    Fuel Pressure too Low
    Leaks in Intake Air System and/or Exhaust System
    Injector(s) faulty (i.e. coked)
Possible Solutions
    Refuel Vehicle
    Check Fuel System Pressure
    Check Mass Air Flow Sensor (G70)
    Check Intake Air System and Exhaust System for Leaks
    Check Injection Quantity
    Check Injector(s)
have u checked these ??
Offline km
« Reply #3 on: 17 January 2012, 18:30 »
as far as i'm aware the car is boosting fine, n75 is couple months old. maf is under a year old.
Offline daz veedub
« Reply #4 on: 17 January 2012, 18:33 »
being aware and being sure are 2 different things mate give it a good checking over everything in the list above
Offline Chris.
« Reply #5 on: 17 January 2012, 18:45 »
Do they come back if you clear them?
Check the pcv pipe in middle of inlet for any splits.
Whats it like with the MAF unplugged?
WHen was the last time plugs were changed?
Click For Build Thread
Offline km
« Reply #6 on: 18 January 2012, 00:26 »
is that the breather pipe? had a huge split in it and replaced with a silicone :)
when maf is unplugged, there's no boost, car is extremely flat!
had new super 4's a few months ago.
Offline james2
  • No scammers please.
« Reply #7 on: 18 January 2012, 19:31 »
if it was the ignition amp ,it will run like a bag of sh!t. It dont give you a fault code. Have you removed the amp from airbox / got a induction kit and relocated the amp ?
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline km
« Reply #8 on: 18 January 2012, 21:55 »
got standard air box on.
not sure how you define run like sh!t, but mine does run like sh!t, only thing is, it's not constant. when the car's idling, it will misfire for about 10 seconds, then go back to normal :undecided:
