Author Topic: Leak Problem!  (Read 4387 times)
Offline mpgscott
Re:Leak Problem!
« Reply #10 on: 27 October 2003, 21:00 »
Check its not coming in the windscreen, I had this prob on my 92 jetta ran a bead of sealent around the windscreen under the rubber and this cured the leak.
1996 VR6 Highline
2007 Aprillia Tuono
Offline KKK
Re:Leak Problem!
« Reply #11 on: 28 October 2003, 19:40 »
If you get water dripping on the fuse box:
Remove the RH speaker cover screw.  When it rains, whip off the cover and check that the RH corner of the windscreen seal is not leaking. (You could always pour a bucket of water over the top of the screen, too!)
If you go to the scrappy and look at the mk2s where someone has removed the windscreen, they all have rust in the bottom corners of the windscreen.
Fix it by spraying waxoyl (or even better, Dinatrol) under the windscreen rubber from top to bottom.
