Author Topic: Mk4 gti help  (Read 1648 times)
Offline denni
Mk4 gti help
« on: 11 January 2012, 20:27 »
Can anyone help me with my mk4 golf gti.... I was driving along and the car made a bang sort of noise kin of like a back fire then cut out, started again and cut out 10-15 yards down the road. Now it starts if i pump te throtle then cuts out. The is no oil or anything anywhere. Im thinking its to do with fuel? There is fuel in it and the fuel light has not come on. Cheers
anyone who can or knows someone that can notch my chassis in south west area please message me!!
Offline topher
  • Administrator
  • fully functioning
Re: Mk4 gti help
« Reply #1 on: 11 January 2012, 20:28 »
1.8T ?
Offline Toby
  • Car - less
Re: Mk4 gti help
« Reply #2 on: 11 January 2012, 20:28 »
What engine? Agu ?
Ignition amp?
Get vag-com and get it scanned.
Currently down under
Offline denni
Re: Mk4 gti help
« Reply #3 on: 11 January 2012, 20:36 »
Sorry yes its a 1.8t
Offline topher
  • Administrator
  • fully functioning
Re: Mk4 gti help
« Reply #4 on: 11 January 2012, 20:39 »
In that case, sounds like you've popped a boost hose off. You can unplug the maf temporarily to trick the car into thinking the air isn't escaping which will keep the engine running long enough to get you home (albeit rather rich and obviously with no boost). Intercooler ones are likely suspects as is the one down the back of the engine that goes over the O/S driveshaft.
Offline daz veedub
  • Operation 1.8t bolf
Re: Mk4 gti help
« Reply #5 on: 11 January 2012, 20:45 »
yep sounds like pipe popped off check all jubilees and pipes  :smiley: like topher said intercooler pipe more than likely
Offline denni
Re: Mk4 gti help
« Reply #6 on: 11 January 2012, 21:29 »
Cheers guys it was the intercooler pipe
