Author Topic: Now that HID's are in MOT got a question.  (Read 2564 times)
Offline Wazzzer
  • Golf GTI 1.8T AGU
Re: Now that HID's are in MOT got a question.
« Reply #10 on: 07 January 2012, 20:34 »
washers don't look too hard to fit, just find some flush fit ones on a car in the scrappy. Just need a separate pump and the bigger washer bottle, plumb it all in, done (I'm saying this like I will be doing it soon  :wink:)
Offline richw911
« Reply #11 on: 07 January 2012, 20:37 »
Think there is a guide on ukmkivs  :smiley:
Offline Chris#101
« Reply #12 on: 07 January 2012, 20:42 »
Just put halogen bulbs in for mot :wink:..................awaitsheadlightpoliceresponse
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Lewisf1988-DUB
  • 1.8T AGU
« Reply #13 on: 07 January 2012, 21:04 »
cheers lads gonna go for some night breakers :)
Offline ditchyboy
« Reply #14 on: 07 January 2012, 21:09 »
do you need to have headlight washers on any car, any age?
Offline clancy
« Reply #15 on: 07 January 2012, 21:21 »
sounds like a plan to me
MK3 GTI 16v
Offline Jimble
« Reply #16 on: 07 January 2012, 21:23 »
nightbreakers only have 30% of the life compared to standard bulbs. they are an improvement over standards
where did you get that?
Apparently the original ones only had a short life but the Nightbreaker Plus are much better which means more expensive!!
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #17 on: 07 January 2012, 21:30 »
osram nightbreakers  :smiley:
+1 got them and much much better
I removed my HIDs the other day and fitted Osrams the other day...now, only now it seems people are flashing me as if to say turn your hi beam off! Whats going? They're f**king uprated bulbs not HIDs...
What 'level' do you all have your scroll light switch on, the small one on right hand side?
Offline clancy
« Reply #18 on: 07 January 2012, 21:32 »
i found this ^^
i have HIDs, also when your driving around you can tell who has HIDs and i have never in my life thought any are too bright. on the other hand i see a lot of new (probably like 2008 onward) cars whos headlights are majorly too bright.
MK3 GTI 16v
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #19 on: 07 January 2012, 21:39 »
the load adjuster should always be set on 0 for driving with normal loads. It is tested on 0 on the MOT
