Author Topic: what is this pipe and where does it go?  (Read 1876 times)
Offline houston
Re: what is this pipe and where does it go?
« Reply #10 on: 07 January 2012, 21:06 »
fair point! i`m intreagued by that intake pipe though  :smiley:
does look good
Offline Big Tone
« Reply #11 on: 08 January 2012, 12:19 »
you on about the pipe that leads to the small filter? that'll be your pcv pipewrork, dont disconnect it unless you want oil vapour coverin your clean engine. which youll probably get with that filter, get a catch can to keep all the sludge away
looks like the pipework to/from the SAP to me.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Scott D
« Reply #12 on: 08 January 2012, 14:17 »
fairly sure it is for the secondary air pump that pipe & filter
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Big Tone
« Reply #13 on: 08 January 2012, 16:06 »
Therefore dont rip it out unless you are deleting the SAP at the same time.
