Author Topic: MK1 Fuel pump  (Read 1734 times)
Offline jimmyp
MK1 Fuel pump
« on: 14 May 2005, 12:06 »
hello
I have put a MK2 1800 digifant engine in my MK1 golf 1300 driver, does anyone know if the Mk1 fuel pump can supply the digifant engine at the right pressure.
i have a mk2 pump but mounting in under the car is a problem i can find enough space.
Offline mk1
Re: MK1 Fuel pump
« Reply #1 on: 15 May 2005, 10:42 »
Yes a mk1 gti fuel pump will flow more than enough fuel for your digi engine, fuel pressure will be OK as the fuel rail has a pressure regulator in it that returns excess fuel back to the tank.
Steve.
Offline jimmyp
Re: MK1 Fuel pump
« Reply #2 on: 15 May 2005, 22:07 »
thanks steve
you don't happen to know were i can get my hands on a set of door rubbers for a mk1, VW have told me they dont make them anymore i have tried a few places up here in scotland but with no luck.
Offline gibby
Re: MK1 Fuel pump
« Reply #3 on: 15 May 2005, 22:17 »
Try these guys for your rubbers (fnarr fnarr  :grin:) www.gpcvwaudi.co.uk  :smiley: Their website looks fooked at the moment but there is a number on there you can see.  :smiley:
......now officially dubless.
Offline black_cabbie
  • If they don't have a golf in heaven I am not going
Re: MK1 Fuel pump
« Reply #4 on: 28 May 2005, 01:39 »
Some comparison pics between the CIS Pump and the silly little digi pump.
CIS is stronger, lasts longer and puts out a higher volume per min.
And thats the fuel pressure in bars you are running when you use a digifant Fuel Pressure Regulator.
1.8L 8V Digifart, AMS chip, Kent 270 camshaft, TT Adjustable Cam Gear, Supersprint Header with supersprint catless system, BMW AFM, Adjustable FPR. G60 Green 23lb injectors coming soon.... =)
