I suspect your rocker cover gasket is leaking
This. Mine was the same. If your still worried do a compression test on each cylinders.
Mine had no smoke, ran perfectly happily (bit rich due to a boost leak I can't find, and I suspect the PCV is clogged a bit) Which suggests nothing catastrophic is wrong. If a ring had gone you'd know about it.
