Author Topic: Central Locking Problem  (Read 3384 times)
Offline GTI EDITION (aka LTD)
Re: Central Locking Problem
« Reply #10 on: 18 May 2005, 13:47 »
Just a thought ,( I know it's a different model but it had the same symptoms)
Yesterday I had a customers  mk4 polos with  a similar problem ( it is an S reg  with the later laser cut keys )
what had happened in this case : the mechanism in the drivers door key barrel had broken which in turn stopped the inner paddle being turned by the key ( stuck in the halfway position ) thus confusing the micro switches for the central locking . I replaced the broken items .. problem solved.!
The problem with the mk4  I have been told that you cannot get the separate parts of the mechanism , you have to order the whole barrel etc by key number from the factory , though not sure how true this is .
Maybe a good idea to check this before ordering a new latch assembly    ( probably is the latch and I know it's a long shot but worth a look ) :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline PaulMK4GTI
« Reply #11 on: 18 May 2005, 18:23 »
Cheers for the thought. However, i think in my case i can rule out the lock barrel cause it does the same thing when i use the remote locking and even the button on the fingerplate. Would it still do this if it was the lock barrel?
Cheers.
