Author Topic: RCD 510 0wners  (Read 6803 times)
Offline p3asa
Re: RCD 510 0wners
« Reply #10 on: 02 January 2012, 21:28 »
I have found the Mix option as described in the handbook, but that only seems to mix up the tracks on the current album being played.
It will only mix the current album you are in.
For example you have 3 albums A, B & C
If you are playing songs from album A and select mix then it will only mix songs from album A
If you want to mix and play songs from all 3 albums then you must have at least 1 song in the root directory i.e. not in any folder.
So if you plug in your USB stick you would see Albums A, B & C and 1 song.  Play the single song and select mix and it will mix from all your songs/albums.
I prefer the navigation of the ipod but it seems to be hit and miss if you will have problems with it. Search for ipod and stutter.
Offline p3asa
Re: RCD 510 0wners
« Reply #11 on: 02 January 2012, 21:30 »
Ok, I've created a file on a separate flash drive with 12 Albums on, but no separate files.
Now I can select random mix, but when I press "Selection" the songs are no longer grouped in their respective albums, so I can't just select one album and play it right through.
Is it just not possible for it to work like a 310 does?
Yeah you can play an album right through the way it is meant to be played or you can mix the album!!! You have full control over it.
Offline Belix
Re: RCD 510 0wners
« Reply #12 on: 03 January 2012, 19:33 »
good to know, always thought it was a bit strange it only shuffles songs in each folder. Odd that it needs one song in the root...
Offline dubber36
Re: RCD 510 0wners
« Reply #13 on: 04 January 2012, 08:35 »
Whoever thought that was a good idea needs sacking, especially when the 310 is so much easier to get to do what you want.
I'm beginging to think that the better looks of the 510 are not enough to justify swapping from (imo) the far superior 310.
Offline dubber36
Re: RCD 510 0wners
« Reply #14 on: 04 January 2012, 13:21 »
On reflection, now I've got it to work, it's perhaps not so bad. I still think it's stupid, but I'm convinced it's worth keeping now.
Offline ajmoir36
Re: RCD 510 0wners
« Reply #15 on: 05 January 2012, 19:53 »
It sure is worth it cheaper than an iPod too. Glad o here you got it working though.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline p3asa
Re: RCD 510 0wners
« Reply #16 on: 05 January 2012, 21:57 »
Dubber is it much different to the way the 310 works?
Offline dubber36
Re: RCD 510 0wners
« Reply #17 on: 06 January 2012, 08:20 »
When playing music from a flash drive on the 310, you get your list of folders, albeit only one displayed on the radio screen at once, then the track list once the folder is opened. At any time you get the option to "Mix folder" or "Mix all"
With the 510, with your help, I have figured out how to get it to "Mix all", BUT once you turn it off, or turn on to the radio, when you turn it back on again, it does not pick up where it left off, and you need to select the root file again to continue random play.
What I am liking about the 510 in the courtesy car is the phone display when the bluetooth is being used.  :cool: Bluetooth for me next I think.
Offline ajmoir36
Re: RCD 510 0wners
« Reply #18 on: 07 January 2012, 01:05 »
You need to perform the mdi firmware update to fix the playing where it left off http://www.my-gti.com/3009/volkswagen-media-device-interface-mdi-firmware-upgrade-0111-kw22-2011 . It worked a treat for me.  Used to drive me nuts that. Now I love how it works.
« Last Edit: 07 January 2012, 01:07 by ajmoir36 »
