Author Topic: backdraft motorsport K04-001 turbo tip?  (Read 16201 times)
Offline jonnyturbo
« on: 30 December 2011, 17:48 »
As above does anyone know if the K04-001 from backdraft use the same diameter tip as the KK03s ? I know it uses same oil lines etc just dosent say anything bout tip size thnks
Offline richw911
Re: backdraft motorsport K04-001 turbo tip?
« Reply #1 on: 30 December 2011, 17:52 »
KO4 is bigger i think  :smiley:
Offline jonnyturbo
« Reply #2 on: 30 December 2011, 17:53 »
Hmm seems strange that it uses factory oil / water lines and down pipe off K03s and yet they changed the tip size LOL cheers rich :afro:
Offline richw911
« Reply #3 on: 30 December 2011, 18:02 »
Im sure someone will know for sure  :smiley:
*Shouts for Topher*
Offline jonnyturbo
« Reply #4 on: 30 December 2011, 18:04 »
LOL
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #5 on: 30 December 2011, 18:08 »
K04-001 is a 100% direct fit from your K03s and the Forge k03s tip will fit spot on :wink:
The turbine internals are bigger, the comp wheel is k03 size but with a new blade confiuration, put the k04-023 cold side on the 001 and you have enough to flow for 299bhp.
Other mods needed to get the 001 on full song are, 386cc BAM/AMK injectors @3bar, then port the collector and runner number 3 on your exhaust manifold.
 01455 617233
jamie16v
« Reply #6 on: 30 December 2011, 18:10 »
try searching google, im sure the compressor wheel in the k04-001 is slightly smaller than the k03s   :drool: not 100% sure though
it does have  a larger turbine wheel though..
the reason the oil/coolant/downpipe ect are the same it because it shares the same turbine housing cast as the k03 and the chra housing is the same for the k03 and k04. it starts do differ when you alter the exhaust housing for one like the k04-023 which is for longitudianal cars like the passat.. to fit one to the golf the S3/TT 225 exhaust manifold, oil/coolant lines and downpipe would be needed.
im not sure exactly what tip size is needed for the k04-001.. i would have thought you could get an aftermarket k03s tip to fit to be honest.
Offline jonnyturbo
« Reply #7 on: 30 December 2011, 18:12 »
Cheers Nick :afro:
Just need a discount code for backdraft now LOL
What sort of bhp / ft lb am I talking of with current mods Nick? Obv turbo needs sorting cos of the wastegate is still sticking every now and then . Cheers Nick
Offline richw911
« Reply #8 on: 30 December 2011, 18:13 »
To late  :laugh:
Offline jonnyturbo
« Reply #9 on: 30 December 2011, 18:18 »
LOL Yip Nick was quick
