Author Topic: Airbag warning light, grr...  (Read 1716 times)
Offline VW Russ
« on: 30 December 2011, 12:11 »
Hi chaps,
wonder if you could help please? I treated myself to a Zenez sat nav system for my mk5 gti over xmas and decided to fit it myself as I couldn't wait until Jan. All went well and works nicely though now I have an airbag failure. I've done a little research and I did switch the ignition on a few times without the switches connected and it appears this could have caused the problem? Anyone else heard of this?
Also, when I removed the pillar interior I wonder if I've damaged tha bag at all? I was careful but you never know.
Any thoughts I would be very greatful.
Many thanks,
Russ
Mk5 GTI 08 in black, DSG, 18" monzas with a Zenec satnav thrown in for good measure.
Offline Mike671
Re: Airbag warning light, grr...
« Reply #1 on: 30 December 2011, 22:53 »
Your not going to know much without plugging in on vag-com or vas
Esplanade V.W Audi Mercedes And Smart Tech
Offline VW Russ
« Reply #2 on: 31 December 2011, 14:36 »
No, I assumed that. Would VW charge much do you think?
Offline Rhyso
« Reply #3 on: 31 December 2011, 15:36 »
If you switched the ignition on with the airbag disconnected, that's the reason it's thrown a light up
local garage with a fault code reader should be able to clear it or find someone who is local with VAGCOM / VCDS who will do it for a beer token or two
One trick you could try is disconnecting the battery for 30 minutes or so.  Sometimes that resets everything
 :smiley:
Offline VW Russ
« Reply #4 on: 31 December 2011, 15:51 »
Cheers Rhyso, that's what I'd heard too. I'll try the battery first if not, I have a friendly garage who I think can do it.
The Zenez sat nav is great by the way, works very well indeed.
