Author Topic: Razor's  (Read 2666 times)
Offline bored_Welsh_lad
Re: Razor's
« Reply #20 on: 30 December 2011, 03:43 »
I am tempted to go down the Double Edged safety razor route, using shaving soap and a badger hair brush.. Especially as I have to shave everyday...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
VW BUSH
Re: Razor's
« Reply #21 on: 30 December 2011, 14:11 »
Best value razors are made my Boston shaving co and sold by boots under hydro brand.
Gillette brands (including Wilkinson) are made to wear out/block after after a prescribed amount of uses per blade and are 100% gimmick.
They actually developed a coating which increased the razor life by a factor of 10, this added about 0.035p per blade but would cut overall sales due to the improved performance.....
The cost of the blades to make and assemble is less than 1p, the holder is less than a pound.
The Isleworth plant made in excess of £100 million before it was shipped to Poland by P&G as it was easier than shutting the under performing Berlin plant.
Expected 5 year turn round on the move was around £600 million
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Razor's
« Reply #22 on: 30 December 2011, 18:52 »
I tried the double edged safety razor, f**k ME! Cut my self to ribbons. Think it takes a bit of getting used to as I believe it is a skill!
I do must shave everyday and use only these products : http://men-u.co.uk/store_products.php?list=1&cat=2&title=Shave+%26amp%3B+Skin
Shave creme is intense, the shaving brushes are brilliant. Mrs got me a real gucci set for xmas :)
Would recommend to anyone!
Offline stealthwolf
Re: Razor's
« Reply #23 on: 30 December 2011, 23:11 »
If you guys go into DE shavin then I suggest you look at mantic59's youtube channel and watch all of his videos.
