Author Topic: Clutch or Gearbox?  (Read 1749 times)
Offline bikeman
Clutch or Gearbox?
« on: 26 December 2011, 20:27 »
My mk4 1.8T is getting difficult to engage 2nd gear from cold start until I've done about half a mile. It's a 99 on 150K miles on orig clutch (no slip yet).
A sign of the clutch going or more expensive gbox troubles to come?
ps happy xmas.
Offline Mike671
Re: Clutch or Gearbox?
« Reply #1 on: 26 December 2011, 20:37 »
Clutch may or help if worn but could be second gear synchro if it's only hard to engage second
Esplanade V.W Audi Mercedes And Smart Tech
Offline gavgtiturbo
« Reply #2 on: 27 December 2011, 10:17 »
my clutch was on its way out with the same symptoms except mine was notchy in 1st and reverse with no slipping or smells untill one day it just went.I tried adjusting the gear linkage to no avail but also noticed the gear linkage bush was warn witch cant help so i changed that too.
Offline xxChrisxx
« Reply #3 on: 27 December 2011, 10:43 »
High shift effort is typically a worn synchro cone. As oil gets round the box shift effort will reduce.
2nd is the gear that gets the most abuse, so it's not surprising that it wears first.
Offline bikeman
« Reply #4 on: 28 December 2011, 21:58 »
Its strange that poor selection is only an issue when cold, once I've done half a mile it's fine. I'm going to try changing the transmission oil and see if that helps. After 150k it'll be a nice treat for the old girl.
Offline bikeman
« Reply #5 on: 04 January 2012, 13:37 »
Bah I changed the oil for some nice clean fully sync 75W90 and it's now worse  arrrrgh :cry:
Whats the ballpark cost to get 2nd synchro sorted?
« Last Edit: 04 January 2012, 13:40 by bikeman »
Offline barrym381
« Reply #6 on: 04 January 2012, 16:46 »
had a box reconed about 4 yr ago for £195 so wouldnt think much more than that
Offline bikeman
« Reply #7 on: 26 January 2012, 16:10 »
Did that include removal/refitting. I just got a quote for £959!!!!!!!!!
Anyone want to buy a mkIV 1.8T?
Offline barrym381
« Reply #8 on: 26 January 2012, 16:33 »
no mate removal/refitting was a £100 quid :smiley:
Offline bikeman
« Reply #9 on: 29 January 2012, 18:43 »
Ha that's the north-south divide for you.....
