Author Topic: Brake Lights...  (Read 3346 times)
Offline xtetx
Re: Brake Lights...
« Reply #10 on: 22 December 2011, 11:19 »
sweet i think ill just change it before it goes if its only £15. Cheers for the help!
Offline ara
  • 2000 Mk4 Golf Gti-Turbo
Re: Brake Lights...
« Reply #11 on: 30 December 2011, 15:19 »
Hi,
I ordered a new brake light switch and installed today following the online instructions.  Why have my brakelights gone from not working at all with the old switch to being stuck on with the new?
Cheers guys...
Offline cliffyj
Re: Brake Lights...
« Reply #12 on: 30 December 2011, 15:47 »
Hi Guys,
   Sorry to jump on this thread, but i have trouble with my n/s brake light. (not working) Mk4 2003 golf)
      The bulb didn't look to have blew, so i swapped it into o/s brake and it works.
          Contact looks ok in n/s, so i was wondering is there a R and L fuse for brake lights?
              Also while i am here, when i turn off engine and leave my lights on by mistake. should i hear some sort of warning to tell me this.
   Hope some one can help.
   Thanks Clifford
Offline Steve_PD
Re: Brake Lights...
« Reply #13 on: 30 December 2011, 16:07 »
Hi,
Cheers guys...
Havent a clue :lipsrsealed: You sure it was installed correctly? Is trhe plunger making contact with the pedal?
Hi Guys,
   Thanks Clifford
http://www.golfgtiforum.co.uk/index.php?topic=87372.0
There is a separate fuse for each tail lamp F22 & F23
Yes you should hear a buzzer. Does the interior light come on when you open the door?
Offline cliffyj
Re: Brake Lights...
« Reply #14 on: 30 December 2011, 16:32 »
Hi Steve,
         No the interior light doesn't come on.
            I had a quick look at those fuses earlier, but will have a 2nd look.(tails lights are still working on n/s ?)
 Thanks
« Last Edit: 30 December 2011, 16:36 by cliffyj »
Offline Steve_PD
Re: Brake Lights...
« Reply #15 on: 30 December 2011, 16:41 »
Door lock moduale is broke. If you get it scanned with vag-com it should throw up a code to confirm it.
Its a separate fuse for each side :undecided:
Offline cliffyj
Re: Brake Lights...
« Reply #16 on: 30 December 2011, 16:49 »
"Door lock module is broke"...... would this cost much to fix Steve, or i can live without it?
  Does it effect anything else in car.
  Clifford
Offline richw911
Re: Brake Lights...
« Reply #17 on: 30 December 2011, 17:08 »
  Clifford
http://www.golfgtiforum.co.uk/index.php?topic=86403.0
Offline cliffyj
Re: Brake Lights...
« Reply #18 on: 30 December 2011, 17:23 »
Thanks for that link Rich, will look into it.
     Clifford
Offline ara
Re: Brake Lights...
« Reply #19 on: 30 December 2011, 18:03 »
My bad...  Went back out into the rain and refitted - works a treat...
