Author Topic: french to german, which mk golf ?  (Read 4393 times)
VW BUSH
Re: french to german, which mk golf ?
« Reply #10 on: 19 December 2011, 21:42 »
Rust is easy to spot on a Mk3.
If the jacking points are mashed, most probably has rust you can pull back the plastic back quite a bit so take a lenser type torch and check well.
Walk away unless it is clearly only minor, that part of the car gets really sprayed in the wet and fills up inside making the rot spread.
The rest is easy to spot.
I have seen a few really solid low mile Mk3's of all engine types going for under £700
Offline CCGTI
  • Fueled Society
« Reply #11 on: 19 December 2011, 22:06 »
My mk3  :wink:
Offline Jack3559
« Reply #12 on: 20 December 2011, 01:26 »
A Mk3 GL doesn't have arch trims so you can check for rust, and it looks cooler in some cases.
Plus, you've then got a great excuse to start thinking about putting a gutsier engine in.
Offline clancy
« Reply #13 on: 20 December 2011, 15:18 »
Aren't the gl small engines ? I'd rather buy a gti and take the arch trims off , that was my plan anyway
MK3 GTI 16v
Offline daz veedub
  • Operation 1.8t bolf
« Reply #14 on: 20 December 2011, 17:51 »
welcome
cant be arsed to go on which is better   :rolleyes: :grin:
Offline clancy
« Reply #15 on: 20 December 2011, 19:14 »
thanks for your help mate, yeah it was jus under the trims i was worried about really.
im lookiing at two mk3s soon with only 2 owners each and under 100K miles so should be pretty good
MK3 GTI 16v
Offline daz veedub
« Reply #16 on: 20 December 2011, 19:41 »
im lookiing at two mk3s soon with only 2 owners each and under 100K miles so should be pretty dud
 :wink: :smiley:
Offline clancy
« Reply #17 on: 21 December 2011, 17:08 »
does 1K seem steep for a mk3 anniversary with low miles or about right?
MK3 GTI 16v
Offline Ninja
  • 19 smiles per gallon
« Reply #18 on: 26 December 2011, 16:34 »
Welcome aboard!
Offline barrym381
« Reply #19 on: 26 December 2011, 23:15 »
can get a mk4 turbo for about tht :smiley:
