Author Topic: bloody chinese spec handles. HELP  (Read 6593 times)
Offline Rain
  • forum irregular
Re: bloody chinese spec handles. HELP
« Reply #10 on: 12 May 2005, 18:23 »
must have been a blind criminal then.........
hate crims.....
was under a car port and at night you cant see ya hand infront of ya face just love to have seen there faces when they tried to get in the drivers seat :D
mix
« Reply #11 on: 12 May 2005, 20:06 »
This could be a good excuse to dehandle cour doors......
DONT DE-HANDLE YOUR DOORS!!!
Nearly failed my MOT yesterday as my chrome ones only open with a key that I only have. You twist the key and the door opens instead of pressing to release. So imagine the trouble youll get into if they were de-handled!
Not too keen on the uprated spec handles though. Think original ones with chrome inserts look cool :wink:
Chrome.......mmmm...... :cool:
Offline BobbyT
« Reply #12 on: 12 May 2005, 20:49 »
i am with blue! just get some rear golf handles and swap the insides of your old ones to the rear one and there you go! delocked and a little smoother looking!  :smiley:
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
« Reply #13 on: 14 May 2005, 22:10 »
 :wink: yeah i had some of these on a Mk 1 when i got it and i thought they were poo!!
Get some nice chrome inserts and get the handles chromed mmmm nice !!  :tongue:
Offline jv
  • Administrator
« Reply #14 on: 13 July 2005, 13:19 »
i've got the mk3 style of these 'chinese spec' handles on mine. they fit and work quite well but needed quite a few washers fitting to the screw that goes inside the door.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #15 on: 13 July 2005, 13:28 »
*Sheps clears his throat loudly*
The greatest leveller of them all - the Carousel
Offline jv
  • Administrator
« Reply #16 on: 13 July 2005, 13:32 »
ha, I was waiting for that.
What I meant to say was, I had a bit of screwdriver rage when the fookin handles wouldn't fit and then sheps bodged fixed them using some washers to push the handles further towards the inside edge of the door so that they open correctly.
Buy site stuff!
Offline S11EPS
« Reply #17 on: 13 July 2005, 13:37 »
Hey, the use of washers is a genuine fix (it even says so in the destructions) it was just my use of electrical ring connectors with the ends chopped off as washers (on the basis I had no washers that fitted) that was a slight bodge sorry, deviation from correct install.
It worked didn't it?  :wink:
Now thatmy garage is tidy and organised, it means that:
a) I can now find proper washers.
b) I have space to store the Rallye interior
Offline j_s
« Reply #18 on: 18 July 2005, 16:20 »
I've just bought these and the rear one as a test fitted and worked fine but the rubber grommets aren't tight to the door so water can get in behind them. I'm going to order some rubber sheets and cut out my own I think to seal the gaps up properly.
James
Offline tinman
« Reply #19 on: 18 July 2005, 18:42 »
you guys do know that putting (nonVW) chinese components on your car will ensure you go to Hell don't you?
