Author Topic: Coil pack warranty---- Now car not running right  (Read 3321 times)
Offline Chris#101
Re: Coil pack warranty---- Now car not running right
« Reply #10 on: 14 December 2011, 20:39 »
are you sure they have replaced all 4
here has never been any mention of numbers. Just assumed they would off all been replaced as its recall!?  :huh:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris#101
« Reply #11 on: 14 December 2011, 20:40 »
Any fault codes? Could be a boost leak.......
Havent got a reader but its still boosting as you can here the blow off
and deffinitely not running on all 4 cyl  :cry:
Offline Chris#101
« Reply #12 on: 14 December 2011, 20:43 »
what are the chances of me getting a courtesy car free of charge do you think !?
as of tomorrow when I take it back it will be 8th trips iv had to make  :rolleyes:
and how would I go about asking, not very good with stringing a polite sentence together
Offline richw911
« Reply #13 on: 14 December 2011, 20:43 »
The reason i say that is because it only miss fires when under load, if a it is a coil pack it usually does it all the time  :undecided:
Order yourself one of these with a mk4 you need it
http://www.ebay.co.uk/itm/VW-VAG-Diagnostic-Fault-Code-Reader-CAN-OBD2-/150667799048?pt=UK_Diagnostic_Tools_Equipment&hash=item2314802a08
Offline harlemex
« Reply #14 on: 14 December 2011, 20:46 »
I agree with Rich, boost leak. Howeber, if you call an explain tomorrow morning they will be fine to book you back again and remedy fault free of charge.  :smiley:
Offline Chris#101
« Reply #15 on: 14 December 2011, 20:48 »
Sorry probably my bad gramar  :grin: but it is 'missfiring' constantly and not running on 4 cyl.
Will be ordering one of those, take its a reputable one  :smiley:
Offline barrym381
« Reply #16 on: 14 December 2011, 20:51 »
pop your engine cover off see if the 3 coils you can see are new
Offline richw911
« Reply #17 on: 14 December 2011, 20:51 »
Well they may not have changed all four as said  :undecided:
Ive got the above reader its great tool to keep in the car  :wink:
Offline daz veedub
  • Operation 1.8t bolf
« Reply #18 on: 14 December 2011, 21:16 »
also have the above reader...................never leave home without it  :cool: :smiley:
unless iam walking  :laugh:
Offline richw911
« Reply #19 on: 14 December 2011, 21:20 »
If you had the reader you would be armed with the fault and not get fobbed off by VW too  :wink:
