Author Topic: silicone hose AGU advice please  (Read 1876 times)
Offline Chris#101
Re: silicone hose AGU advice please
« Reply #10 on: 13 December 2011, 18:27 »
Before you going buying any hoses, I've got a brand new set that I'm trying to sell! Let me know cheers
 http://www.golfgtiforum.co.uk/index.php?topic=212524.0
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« Reply #11 on: 13 December 2011, 20:45 »
Hi mate,tip is turbo intake pipe at bk of engine bay,u need intercooler to throttle body hose im thinking,thats about £80-£90 for a forge one i believe.you will probably need to trim the ends a bit to get a really good fit i did with mine easy enough to do though :smiley:
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
