Author Topic: Running an ABF head on a KR block  (Read 6970 times)
Offline danny_p
Re: Running an ABF head on a KR block
« Reply #10 on: 13 December 2011, 20:14 »
you need a CR of 8:1   right, well std KR pistons gasket and head are going to give you 10:1
also are you on about early or late KR heads
the ABF head ain't much diffrent form a late KR head, ports better valve guides shorter,  more clearance for cams  but thats about it.
G60 pistons in a 16v would give you a CR 0f   0.f**k all :1
1) 16v pistons are domed,   std 8v pistons are dished and give 8:1 when used with a 16v head    g60 pistons are inverted buckets and give 8:1 with an 8v head   and youd have to notch them to clear the intake valves anyway
all the VW's have gone bar 1.
Offline Sam
  • Sam I am
« Reply #11 on: 13 December 2011, 21:12 »
At the moment I run bushed standard kr piston rods and standard everything else so have a cr of 8:1 to suit the turbo thus.. i need to maintain this CR.
 I'm merely asking about running an ABF head on a KR block, I'm not after any advantage or anything like that. Just if one came up cheap would my CR stay the same or merely differ to something like 8.5:1? I'm not sure which KR head I'm running, my car is an 89 if that helps?
I wasn't asking about running G60 pistons, just chasing figures around the page that I linked as an example. So could I use standard 16v rods and 8v pistons to achieve the 8:1? Not that that's really relevant to what I'm asking, just interested.
Original question revised, what is the compretion ratio of a ABF head on a KR block and will it work?
Offline tomp
« Reply #12 on: 13 December 2011, 21:30 »
http://www.ebay.co.uk/itm/VW-CORRADO-16V-KR-CYLINDER-HEAD-RECONDITIONED-GOLF-GTI-/220754944148?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3366052094
Looks good to me....
Anyone know if it fits on the Golf? If so its a bargain Sam and the works already been done....
Offline danny_p
« Reply #15 on: 13 December 2011, 21:40 »
CR of ABF head on KR block will be near as dammit the same as KR head on KR block
Offline Sam
  • Sam I am
« Reply #16 on: 13 December 2011, 22:04 »
And the fitting is the same? i know the ABF has a slightly higher deg cam setup on it but also has a bigger valve interference (if im reading this right) especially on the intake ala..
2L 16V ABF cam specs:
Intake - 219deg @ 1mm, 10.8mm max
Exhaust - 220 deg @ 1mm, 10.8mm max
1.8L 16V KR cam specs:
Intake - 218deg @ 1mm, 9.6mm max
Exhaust - 226 deg @1mm, 10.2mm max
And the pistons in my block have a valve clearance indent on the front ala..
rather than a flat crown. Stop me if I'm heading in the wrong direction here but I don't want it to smash the valves in when I first try starting her.
ps. ignore the shape of that piston haha
Offline danny_p
« Reply #17 on: 13 December 2011, 22:08 »
to lower the compression you pistons will have been bushed down. so more clearance
also all 16v pistons have clearanceing for the intake valves
you can put kr cams in an abf head if you wish
Offline Sam
  • Sam I am
« Reply #18 on: 13 December 2011, 22:16 »
I would stick with the ABF cam as it offers a little more. I cant remeber off hand how large the bushings are on the con rods. So the ABF head fully lines up? Just a straight swap  :smiley:
