Author Topic: 1.8t boost valve controller  (Read 11533 times)
Offline pickles
  • Next!!!
Re: 1.8t boost valve controller
« Reply #10 on: 14 December 2011, 23:32 »
Depends how far you want to push.
My AGU injectors topped out at around 235bhp.
My stage 2 setup:
k03s turbo with forge actuator with yellow spring (makes a huge difference and gets higher peak power figures + holds power far better)
new N75
new maf
VR6 maf housing
pipercross panel filter in smoothed airbox with cold air feed to bumper
thanks alot mate, got a few bits n pieces
Forge TIP (needed to fit a k03s to a AGU
Ebay decat
Homemade 2.5" exhaust
THS intercooler (needed for stage 2) (or FMIC)
Calira turbo yellow injectors
007p with yellow spring
PCV deleted
charcoal canister deleted
Throttle body mod
3bar FPR
Injectors and MAf housing aint needed if you pushing power.
thanks m8, was that 235 on a stage 1 with standard injectors, got a few bits n pieces already, is there not much needed for a stage 1 map then, cos a lot o the stuff i was gna do anyway u had mentioned for your stage 2 setup, whats the TB mod and what do  u mean by "Injectors and MAf housing aint needed if you pushing power., cheers bud ur a star :)
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
« Reply #11 on: 14 December 2011, 23:34 »
you grind a bit out the limit stop on the cable throttle to allow it to open up fully, have u any pics of this m8, i have a grinder :) lol.
Mapped
Nearly S3 time  :)
Offline Chris.
« Reply #12 on: 14 December 2011, 23:35 »
No, ive never had a stage 1.
Ive always got R-tech to do my custom maps for me...so stage 2 custom mapped.
When you push power, the stock maf housing becomes restrictive, only allowing about 187g/s of air through it....so you need a bigger housing to flow more air and get adjustments in the ECU.  SAme with the injectors, they are on max duty cycle at 235ish bhp.
Oh, need a good fuel pump too.
Pickles....Nope....precess of ellimination really with vagcom.  Dremel or a good file will be enough.
Click For Build Thread
Offline pickles
  • Next!!!
« Reply #13 on: 14 December 2011, 23:39 »
you got 235 bhp out a stage 2 map do u mean, surely this is a bit low, ive heard of ppl squeezing 230-240 with a stage 1 map
Mapped
Nearly S3 time  :)
Offline Chris.
« Reply #14 on: 14 December 2011, 23:44 »
Stage 1 k03s is typcially 210-225.
Its VERY hard to push over 230bhp without a actuator on.
Plus stage 2 tends to get more area under the graph and work on getting a nice smooth graph.  Peak figures are only good for the pub
Offline pickles
  • Next!!!
« Reply #15 on: 14 December 2011, 23:57 »
what actuator are u referring to bud
Mapped
Nearly S3 time  :)
Offline Chris.
« Reply #16 on: 14 December 2011, 23:57 »
Forge one is needed for anything over 230bhp.  with yellow spring.
Offline pickles
  • Next!!!
« Reply #17 on: 15 December 2011, 00:16 »
as in a 007p DV, iv got 1 with the green spring, easy to change the spring tho
Mapped
Nearly S3 time  :)
Offline Chris.
« Reply #18 on: 15 December 2011, 00:19 »
No.  Actuator.
Offline pickles
  • Next!!!
« Reply #19 on: 15 December 2011, 00:25 »
u mean the wastgate on the turbo itself, soz im just gettin my head round turbo setups, got a thousand questions lol
Mapped
Nearly S3 time  :)
