Author Topic: Toyosport Induction Kit Part ?  (Read 3448 times)
Offline pickles
  • Next!!!
« on: 12 December 2011, 18:24 »
http://by151w.bay151.mail.live.com/att/GetAttachment.aspx?tnail=0&messageId=85956a18-24ed-11e1-ab82-00237de41626&Aux=0|0|8CE8711723F6650||0|0|0|0||&maxwidth=220&maxheight=160&size=Att
dunno if u can see the above link, but i bought the kit from here http://www.toyosports.co.uk/cold-air-induction-intake-18t-golfjettagti--octavia-3999-519-p.asp
had to cut the metal pipe to allow it to fit just behind my battery btw
just wondered what the hose and additional filter will be for, could it be no longer used because ive had to cut the pipe perhaps ?
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
Re: Toyosport Induction Kit Part ?
« Reply #1 on: 13 December 2011, 11:59 »
bump
Mapped
Nearly S3 time  :)
Offline Chris#101
« Reply #2 on: 13 December 2011, 12:25 »
Its a breather filter  :wink:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline pickles
  • Next!!!
« Reply #3 on: 13 December 2011, 12:30 »
for where tho and what about the blue hose
Mapped
Nearly S3 time  :)
« Reply #4 on: 13 December 2011, 12:56 »
Its a breather filterĀ  :wink:
The blue hose and adaptor go into the end of the SAI pipe, you should have a small stub on the metal pipe that it fits on, if not just fit the small filter into the end of the SAI pipe.
Offline pickles
  • Next!!!
« Reply #5 on: 13 December 2011, 13:02 »
cheers, ive had to hacksaw the pipe to enable it to fit and iv cut this stub off i believe, where this sai located if u dont mind :)
Mapped
Nearly S3 time  :)
« Reply #6 on: 13 December 2011, 13:41 »
It is the pipe that clips onto the std airbox
Offline pickles
  • Next!!!
« Reply #7 on: 13 December 2011, 18:30 »
i never had any other pipes connected to my std airbox, only the big TIP n MAP pipe, which is now connected to said induction kit
Mapped
Nearly S3 time  :)
Offline Dave_IOW
« Reply #8 on: 13 December 2011, 19:24 »
You dont have any use for this as you have an AGU engine, without this SAI rediculousness...
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline pickles
  • Next!!!
« Reply #9 on: 13 December 2011, 19:30 »
cheers,  rediculousness...??
Mapped
Nearly S3 time  :)
