Author Topic: Jonrandom 1.8t TD05 16G build  (Read 172144 times)
Offline jonrandom
Re: Jonrandom 1.8t TD05 16G build
« Reply #170 on: 22 May 2012, 07:08 »
sweet, you going to ceramic cote them or anything?
No will leave them lots of it is silicone elbows, may ceramic coat the manifold in the long run but will give it a bit of time to make sure it doesnt crack.
Offline jonrandom
« Reply #171 on: 23 May 2012, 20:00 »
Bits came today
Fitted up all the pipe work and it fit quite well.
Just need to weld on pipes for the 007 and the EBC which ill do on fri.
Now have 2.5" pipe work from turbo to throttle body.  :smiley:
Bought T-bolt pipe clips that were to small tho so they have got to go back for bigger ones  :embarassed:
Offline jonrandom
« Reply #172 on: 27 May 2012, 19:56 »
I tried to fit wheel spacers to the rear and found that one side fit fine but the other wouldnt so had to get it on the lathe to take some of it out to get it over the extra bit on the hub. Worked a treat.
Welded the extra pipes on so I could fit the dump valve and EBC
Drilled and tapped the pipework to fit the nozzle for the WMI
Made up a brace to help hold the turbo to the block for extra support just need to weld it up.
Have sent off my rear calipers to Bigg Red to be reconditioned hopefully should get them back this wk  :smiley:
Offline daz veedub
  • Operation 1.8t bolf
« Reply #173 on: 27 May 2012, 19:58 »
cant wait see this at inters great work mate
Offline jonrandom
« Reply #174 on: 27 May 2012, 20:10 »
Cheers mate should be good cant wait to get it back on the road its been along time.
Will be good to meet some people as well looking forward to seeing your bolf mate.  :smiley:
Offline Dave_IOW
« Reply #175 on: 27 May 2012, 21:36 »
Just reminded me to book ticket!
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline daz veedub
« Reply #176 on: 27 May 2012, 21:37 »
bloody hell dave  :rolleyes: :rolleyes: :grin:
Offline Dave_IOW
« Reply #177 on: 27 May 2012, 21:39 »
Plans changed  :grin:
Offline jonrandom
« Reply #179 on: 29 May 2012, 17:52 »
Yeah cheers Jack I will do  :smiley:
Same you cant make it, ill defo go just a shame ill still be running the car in so no sprints  :sad:
Next time!  :evil:
