Author Topic: sh!t-shaped utility motoring  (Read 187493 times)
Offline Diamond Hell
  • Opinions я Us
Re: sh!t-shaped utility motoring
« Reply #380 on: 05 September 2013, 10:55 »
Self inflicted death or through sheer punishment?
It continues in a stable condition, although MPG appears to be depressed in the past few weeks, for some reason.
Might be the extra drag from the poorly-fitting indicator....
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #381 on: 05 September 2013, 12:07 »
Yeah im guessing the drag co-efficiency has sky rocketed with that gaping hole in the wing. So now you're not only a danger to other road users you are infact destroying the environment with your frivolous use of oil.
Offline dom
  • Back in a Mk4
« Reply #382 on: 06 September 2013, 11:35 »
Well the last few pages made for an entertaining read :grin:
Offline Dave_IOW
« Reply #383 on: 23 September 2013, 23:25 »
Your right about tea cup positioning.
RIP green cup, sadly missed, easily replaced.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
  • Opinions я Us
« Reply #384 on: 01 October 2013, 11:26 »
So, Mrs Hell takes it out this morning.
Brings it back having smashed one wiper into the other because the wiper linkage has fallen to pieces, after only +180k miles.
Shoddy.
Took it to Beaconsfield and back last week, up the M3, M25 and M40.
The side-repeater is precisely where it was when it was fitted.
Because POS car.
  • Opinions я Us
« Reply #385 on: 04 October 2013, 17:23 »
Fixed the wiper mech last night.  As I suspected the linkage had fallen apart.  I did have another unsuitable mech sitting around which I contemplated robbing the missing part off, but figured out would do the same again so gobbed a washer over the end of the shaft the linkage had fallen apart on.  That won'tbe coming apart again.
Offline Luke1981
« Reply #386 on: 07 October 2013, 16:16 »
Dodgy indicator light and now the wiper mechanism fixed with only a washer. It's a death trap and only a matter of time before someone is killed  :grin:
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline SoundillusioN
« Reply #387 on: 07 October 2013, 18:22 »
I've missed this place.  :grin:
  • Opinions я Us
« Reply #388 on: 27 November 2013, 08:16 »
The indicator is still present and correct where it was clipped.
However, I was concerned my back end had been becoming increasingly mobile.  On closer inspection both rear dampers had been sick down themselves.
Thankfully a nice man had some virtually brand new Munroe dampers and showed up with them last weekend.
Out with the old:
Which included this highlight of a spring cap  :shocked:
Which has obviously rotted out and then cracked open.
Back end is now much tighter and is sitting a bit higher.  Might change back to the old springs, which appear to be rather more tired than those now fitted, which isn't a bad thing with new dampers under them.
  • Opinions я Us
« Reply #389 on: 29 November 2013, 00:35 »
Due to a lack of Corrado parts I resorted to fannying about with this tonight.
Replaced a couple of blown bulbs in the cluster, so I can see the time and mileage at night.  Also replaced the heater panel bulb, too.
Then tightened the handbrake cables, although I suspect the shoes need replacing at the back.
There's a knock from somewhere occasionally, which is annoying.  Need to inspect the rear beam bushings when the Corrado is off the ramp.
220 miles in it in the last 24 hours, up to Beaconsfield and back.
Obviously the side repeater light hasn't moved.
