Author Topic: sh!t-shaped utility motoring  (Read 187262 times)
Offline Dave_IOW
Re: sh!t-shaped utility motoring
« Reply #250 on: 11 May 2012, 19:51 »
Someone's starting to get attached   :rolleyes:
 :grin:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #251 on: 11 May 2012, 21:18 »
It does appear that way, this time next year it'll be concours entries.
Offline Diamond Hell
  • Opinions я Us
« Reply #252 on: 11 May 2012, 21:31 »
Tis purely utility motoring - these are all functional improvements.
If it passes its MOT in August it'll get further improvements.
No point having a cheap-as-chips sh*tter if one doesn't take pleasure from spanking it relentlessly.
I am punishing this Golf3 on behalf of all those out there who don't have the gumption to spank their Golf3s themselves.
Offline JC
  • Back in the North.
« Reply #253 on: 12 May 2012, 16:31 »
you love it, Dave knows the truth.. . . . . . .
  • Opinions я Us
« Reply #254 on: 30 July 2012, 17:06 »
It has another MOT - I went to re-tax it and found out the MOT ran out the day before - whoops!
Advisories - apparently the ARB bushes are worn, the front top mounts are worn, both rear wheel bearings 'play' (I'm guessing they're worn) and there is some corrosion to both sills.
So, a fair assessment would be 'it's a bit worn'.
Odo now reading 173400.  Last tank of fuel was drunk at 47.5MPG.  I should probably change the air filter to restore that 3MPG.  I did say if it went through an MOT I'd replace the thermostat, as it only comes up to 70deg C.  I should probably swap in my 280mm vented fronts as well and (nearly as importantly) swap the brake fluid to encourage it to stop.
If I was feeling really kindly I'd even change the oil, but I think it should do another few miles before that happens.
Offline SoundillusioN
« Reply #255 on: 30 July 2012, 18:31 »
Well done shi*ter.  :grin:
You can't be spanking it enough if you're returning that kind of mpg.  :rolleyes:
Don't worry about changing the oil, it will burn it off soon enough.  :grin:
  • Opinions я Us
« Reply #256 on: 30 July 2012, 20:28 »
That's the thing - it doesn't burn much oil.  Don't worry I am being quite unkind enough to it and still it returns those MPG figures.  It's sickening.
Offline JC
« Reply #257 on: 30 July 2012, 20:30 »
dont waste the brakes on that  :rolleyes: I know a green mk2 they can go on  :kiss:
  • Opinions я Us
« Reply #258 on: 30 July 2012, 23:04 »
Oh I assure you the brakes will not be wasted on it.
It also has the advantage of giving me a spare pair of hubs for the Syncro, in case wheel bearings go.
« Reply #259 on: 31 July 2012, 00:18 »
With those miles I must say I'm impressed!  :embarassed:  :grin:
I know you will never be kind to it so I believe you. Well actually you are in a way as you haven't set fire to it yet. It's matching what the Mazda does when I drive it super nicely!
A rolling donor.  :grin:
