Author Topic: thats another wheel drum f*cked then . . .  (Read 3114 times)
Offline leigh_harty
  • Audi AGU
Re: thats another wheel drum f*cked then . . .
« Reply #10 on: 09 December 2011, 19:31 »
Don't some fords Or mini's come in 4x98? A possible cause...
Dont lose your dinosaur!
Offline Cory
« Reply #11 on: 10 December 2011, 15:23 »
i think i know whats caused the problem now. the old bolts and drums have some corrosion on them for some reason. probably my fault getting the bolts dirty when doing coilovers, rear axle bushes, brakes and a few other bits all at the same time at the start of summer.
new drum, bearing and bolts on one side and all seems tickedy-boo. just waiting on another drum to be delivered and ill have a car again
Offline Chris.
« Reply #12 on: 10 December 2011, 16:45 »
copperslip helps.
Click For Build Thread
Offline Diamond Hell
  • Opinions я Us
« Reply #13 on: 10 December 2011, 18:10 »
copperslip helps.
NO
You want your wheel bolts to stay where they are.  The threads should be clean and dry, not with something smeared all over them which is specifically designed to stop things seizing where they are (i.e. not coming loose!).
Offline Chris.
« Reply #14 on: 10 December 2011, 18:12 »
Wildly debated topic.....LOTs of people put copperslip on wheelbolts.
Offline SoundillusioN
« Reply #15 on: 10 December 2011, 19:28 »
Lots of people self harm.  :rolleyes:
Offline travisreeve
« Reply #16 on: 11 December 2011, 18:38 »
Copperslip on wheel bolts is an mot failier if the mot tester was to check them
Offline cняis
« Reply #17 on: 11 December 2011, 20:07 »
Our MOT testers only check that bolts are all present (if the bolts can be seen), and NOT whether they're smeared with grease.
The local tyre place always uses a thin smear of copper slip.
Offline travisreeve
« Reply #18 on: 11 December 2011, 20:32 »
only goin by what other mot testers have said
Offline tweed
« Reply #19 on: 11 December 2011, 21:33 »
you don't copperslip the threads, you copperslip the tapper.
