Author Topic: Haynes Manual  (Read 3375 times)
Offline kniterider
  • had most, sold most and often buy more!
Re: Haynes Manual
« Reply #10 on: 10 May 2005, 18:45 »
you wanna try and get that bentley jobby........ been told (think by corrin) far better than haynes, im gonna try and download the bentley stuff tonight.... dunno what for like, but then if any one needs out i can send.......
i used to have a haynes manual, for the mk2 havent a clue where it is... still got my mk4 one... even though alot of the info in it regarding my engine rebuild was INCORRECT!!
 :rolleyes:
wotto, ignition barrels piece of cake make, take off your plastic shrouding and  youll then see how easy it is...
Offline kniterider
Re: Haynes Manual
« Reply #11 on: 10 May 2005, 18:55 »
just seen that online version of bentley thats in a link in mk2 section, sh@te hot stuff!!!
 :smiley:
Offline AudiA8Quattro
Re: Haynes Manual
« Reply #12 on: 10 May 2005, 19:32 »
There is a mk2 bentley manual on ebay at the moment.
The barrel is a very difficuly/easy job depending on year.
Early models, the barrel will come straight off, on later models, there is a sleeve on the steering column that will need to be removed. This is very difficult to remove without a puller.
Offline Organisys
  • Old and Slow...
Re: Haynes Manual
« Reply #13 on: 10 May 2005, 19:34 »
Just for interest, I have both green and red manuals. They contradict one another in the section on adjusting your CO content (Digifant models). One states to turn the adjusting screw clockwise and the other states turn it anti-clockwise. I was trying to reduce my CO content using the instructions in the green manual and ended up with a CO content of 8.5% (should be 1%). Only realised the mistake when my car was running sh..e and I borrowed my neighbours CO analyser. I bought the red book recently on ebay for about £7.00, it certainly is a lot thinner than the green one.
Interesting....what exactly is the difference between these two coloured editions please anyone?
Offline kniterider
Re: Haynes Manual
« Reply #14 on: 10 May 2005, 19:46 »
yeah mine was on the earlier one i think, i never had to pull a ring off ooo errr!, is it something to do with the later ones with the hazard light on top of the shroud?? what sort is yours wotto?
mrwotto
Re: Haynes Manual
« Reply #15 on: 10 May 2005, 19:52 »
My hazard  switch is on top of the steerring column if thats what you mean gaz?
Offline saldavorescobar
Re: Haynes Manual
« Reply #16 on: 12 May 2005, 15:43 »
I have a spare mk2 manual (the red one) it's pretty tatty. Give us a £5 for it. That should cover the postage easily.
PM me your address and I'll get it over to you.
Cheers, sal.
Offline monzablue16v
Re: Haynes Manual
« Reply #17 on: 14 May 2005, 21:46 »
just remember to put the key in the off position to remove after drilling the hole otherwise you spend hours swearing trying to pull it with the key in the on position and then it takes two seconds in the off position, how do i know that i wonder???
Veedubgt18v
Re: Haynes Manual
« Reply #18 on: 15 May 2005, 09:56 »
i think the red one is just basically a scaled down edition that caters generally for all models, the green one seems to have more detailed digrams etc and go into some more detail on fault findong and testing etc
