Author Topic: Heavy clutch, is this normal?  (Read 4450 times)
Offline tinman
Re: Heavy clutch, is this normal?
« Reply #10 on: 09 May 2005, 00:05 »
cant agree. my valver was 4 when i got it and its always been heavy. i also test drove one of the last ones in 91 and it was equally heavy. i also drove a friends 16v all those years ago and found it exactly the same. i must of driven three duds.
Offline AudiA8Quattro
« Reply #11 on: 09 May 2005, 00:09 »
Did you drive one with a brand new clutch and cable fitted?
Its certainly very light compared with the vr6  :laugh:
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
« Reply #12 on: 09 May 2005, 00:53 »
yeah mine is so much lighter since i fitted a new clutch on it!   :laugh:
Offline tinman
« Reply #13 on: 09 May 2005, 11:39 »
strange, i test drove a VR6 just after they came out (revenge for the dealership charging £5 to refill the windscreen res during a service on the 16v).
the vr6 had a much much lighter clutch.
Offline GTI EDITION (aka LTD)
« Reply #14 on: 09 May 2005, 13:19 »
A few thing to consider :
                                  1: The clutch can feel heavy if the cable has worn ( over time )through the nylon inner casing .
                                  2: If the clutch is VERY heavy it can break the quadrant in the end of the gear box ( behind the green circular plate on the end... quite easy to replace )
                                  3; In extreme circumstances the center release shaft/rod ( which slides inside the input shaft ) can punch a hole through the center release plate in the clutch assembly ( I have seen a few that have done this ) . This makes it a right bu66er to get the box out as the release rod tends to get stuck  and you  can end up bending the rod and knackering the small oil seal and bronze bush in the end of the inputshaft.
  N.B. I would always recomend replacing the oil seal and bush when replacing the clutch assembly ( a small price to pay compared with replacing ( an oil contaminated  ) plate a few days later !!!   :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
« Reply #15 on: 10 May 2005, 14:29 »
Replace the cable before you do anything else. Get yourself down to Halfords the manual cables are on clearance, I got one yesterday for £5!! :D
Edit: The clutch on my MK2 driver was quite heavy, but not too bad.  I fitted the clutch spring from a MK2 16v and it was better.  I also replaced the cable and it was much lighter for a while, but gradually went back to normal (non genuine cable from GSF)
« Last Edit: 10 May 2005, 14:31 by rubjonny »
Offline Mr Blue
« Reply #16 on: 10 May 2005, 15:19 »
ive had a few gti's and all the clutches seem to be lighter than newer cars :rolleyes:
someone was telling me that a heavy clutch could be related to the release fork/bearing. is this true ?
« Last Edit: 10 May 2005, 15:23 by Blue Mk2 »
Veedubgt18v
« Reply #17 on: 11 May 2005, 10:22 »
i used to think my clutch was light and it is compared to marks 16v but then i had a new clutch fitted. but the other day i drove an audi a3 brand new and damn the clutch weas like a button made me realise how old our cars are getting.........
and it had weird adaptive steering bollies
Offline the_GTI_new_guy
« Reply #18 on: 11 May 2005, 20:56 »
Where should the bite ing pount be. Mine is 1/2 to 3/4 way up. Works fine just wondered if this is the norm.
Offline MR.V
« Reply #19 on: 12 May 2005, 11:10 »
i had this take out the clutch cable oil/grease it and then put it back problem solved! :smiley:
