Author Topic: wheel spacers  (Read 2269 times)
Offline Mr Blue
Re: wheel spacers
« Reply #10 on: 17 December 2011, 00:00 »
get some hub centrics. you will be fine.
Many of us run hub adaptors with no problems. You do need some loctite on the adaptor bolts. Thats about it!
« Last Edit: 17 December 2011, 12:04 by Mr Blue »
Offline Diamond Hell
  • Opinions я Us
Re: wheel spacers
« Reply #11 on: 17 December 2011, 10:35 »
even on track they are ok  :grin:
(within reason, no leepu specials)
Funny - I've been at a track day where someone resolved vibration issues by removing their wheel spacers.
But then I'm not trying to justify using wheel spacers.
Better to use the right wheels out of the box than bodging with spacers.
VeeDubGTI16v
Re: wheel spacers
« Reply #12 on: 17 December 2011, 10:50 »
The right wheels, as in lower offset? is that not exactly the same as using spacers? if the op wanted to fit a different stud pattern wheel he would have said adapters and not spacers.
The someone at a trackday shouldn't have bought cheap/unbalanced spacers. Probably the 4/5 stud multi fit type
Using the one case study equals the general rule theory you tend to use, I have used spacers on the rear of mine on most of its trackdays with no problems, and the rear bearing design on the mk2 is pony compared to the front. Pictures of it going on track with r888's on shows the rear wheel toe differing either side through flex so they have a bloody hard time
