Author Topic: AUQ 180 smoking *Now with video*  (Read 1416 times)
Offline Chris#101
« on: 03 December 2011, 15:29 »
Well Iv just fitted my 3" stainless turbo back system and my car seems to be smoking white/blue smoke when you rev it :undecided:
It did this everynow and again on first initialy start up of the day ie when the engine was cold litteraly for a few seconds (almost like it was clearing itself out) but now it smokes on pretty much every rev when the engine is hot or cold :sick:.
*Edit*
I have also noticed that my exhaust emmisions light has come on the dash could this have anything to do with it?
any advice welcome please?
VIDEO
http://www.youtube.com/watch?v=Qfo1FeInM5U
« Last Edit: 03 December 2011, 16:08 by Chris#101 »
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline sharki786
  • GOT BOOST??
Re: AUQ 180 smoking *Now with video*
« Reply #1 on: 04 December 2011, 18:46 »
checked your oil levels? could be a number of things (turbo seals)?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Chris#101
« Reply #2 on: 04 December 2011, 23:55 »
Iv been keeping a close eye on all levels and ask appear ok and theres no water.in the oil and vice versa.
How ever I'm.not sure if its burning oil or over fueling as ever since fitting the exhaust iv got the emmision warning light on my dash as its a straight through pipe no cats!?
Offline dilbert
« Reply #3 on: 05 December 2011, 08:26 »
you say it usually does it 1st start up when cold, that's usually a sign of valve oil seals perished and oil leaking past the valve seals and sitting on top of the piston, then when started up the oil will burn which causes the smoke.
mk4 golf 1.8 gti 20v
Offline gti gaz
« Reply #4 on: 08 December 2011, 20:59 »
sounds like valve seals to mei would recon your head or get one thats already done i know its no easy task but you will be able to see more of whats going on with it off           hope it helps
 Any one in cornwall lets sort more meets!!!!
