Being new to this forum, this query has probably been asked before, but I have not found the correct answer, so hoping someone out there will be able to help.
The problem. 1986 Scirroco GTX. Runs ok, however the electrics are causing me a small problem. Only part of the dash works, ie the warning/information lights. There is no temp gauge, the thermostat valve works but the fan doesnt function when the engine is getting hot, the rev counter doesnt work and the fuel gauge is also not working. I recall from a previous GTX that when the ignition is turned to position 1, the battery and oil lights come on, right now it is only the battery light which illuminates when the key is turned. I have gone through the wiring diagram and I am obviously missing something as other module units on the same circuit pos/earth are working.
Any help would be appreciated
