Author Topic: Can I borrow a rear beam bush 'tool'..... Anyone?  (Read 4523 times)
Offline bricey
  • One of a few with a PROPER engine
Re: Can I borrow a rear beam bush 'tool'..... Anyone?
« Reply #20 on: 07 December 2011, 16:23 »
ow did you know they needed replacing?
i only ask as my car's making some horrid noises while going over bumps in the road...
DOLPHIN TRAINER
Offline GunnerCP
« Reply #21 on: 07 December 2011, 16:28 »
um... well, my boredom told me.....
on a more serious note, think basically you get a harsh banging over small potholes or whatnot in the road and the rear end can feel 'vague'...
Offline pickles
  • Next!!!
« Reply #22 on: 14 December 2011, 23:55 »
http://www.toolbox.co.uk/link/1/VS722_V2_P.PDF
seems to be instructions on how to make your own 1 i think, what other diy devices to ppl use, who said earlier bout some washers and flat plare ??
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Chris.
« Reply #23 on: 14 December 2011, 23:57 »
Easier to attack the rubber with a drill, then cut 2 lines in the bush casing with a hacksaw, then get a socket slightly smaller than the hole in the axle and hit it with a hammer numerous times.
Click For Build Thread
Offline GunnerCP
« Reply #24 on: 15 December 2011, 00:01 »
But that would have ruined the fun! I got rid of so much stress that day  :laugh:
On a side note, I did drill them but don't have a power supply in my garage and can't really run an extension. My cordless makita is hundreds of miles away so borrowed some cheap thing that had no guts..... It was relatively simple in the end, made a meal of the first one though.
Offline Chris.
« Reply #25 on: 15 December 2011, 00:04 »
Ha.  I did 4 on the back of a transit yesterday and they were seized solid!  I ran a drill round between rubber and casing,  popped rubber out and did the above post with 2 lines.
Offline pickles
  • Next!!!
« Reply #26 on: 15 December 2011, 00:05 »
Some m10 stud bar, plate washers and a couple of bits of 1" angle iron (or anything similar to use as packing) is all you need to get them in pal.
any1 have any pics of this home made tool, sounds very useful
Mapped
Nearly S3 time  :)
