Author Topic: LIST OF PARTS NEEDED FOR 20VT INTO MK3 CONVERSION  (Read 205633 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: LIST OF PARTS NEEDED FOR 20VT INTO MK3 CONVERSION
« Reply #30 on: 05 January 2012, 17:29 »
well mine is near 300ilft and no issues
I'm running a sachs VR6 item with 16v Flywheel
My car goes back for more mapping on the 23rd
I wouldn't advise any cheap clutches tbh..
Whats the spec of your car ?
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline jinx
« Reply #31 on: 09 January 2012, 18:56 »
Spec is MK3 1.8t AGU with some nice upgraded internals and an IHI VF34
got 2 rr printouts, one from 2 years ago with nearly 360bhp and 412 Torque
the other one i got done a week before the clutch went, it showed a drop of 20hp and just 266 torque
So i've put my hand in my wallet and bought a flywheel and clutch that should handle 470 torque, just hope it's ok for daily driving.
Be nice to reclaim some of those torques
Offline popleyruss
« Reply #32 on: 10 January 2012, 00:26 »
Yea mate they are the same
Mine is still on its 8v drive shafts. They were the same as the 16v ones
Hi mate lookd at the driveshafts there not big enough for the gearbox cups ?? What ones should I use ?? Are the mk3 gti ones longer ?? The car is a cabrio it's not classd as a gti
Just plain dubbin
Offline F17BAD
« Reply #33 on: 10 January 2012, 18:37 »
yeah mate use GTI ones, mine are the GTI ones, does not matter if they are 8v or 16v
Offline popleyruss
« Reply #34 on: 11 January 2012, 00:05 »
U can tell I'd been up more than 24 hours lol I offerd the driveshafts up to the mk4 box lol
What throttle cable shal I use ???
Just plain dubbin
Offline danmusic24
« Reply #35 on: 11 January 2012, 10:43 »
how much work is it to alta the wiring loom? is this something you could do yourself? is just a case of changing a few connectors over or a bit more than that?...
thanks dan :smiley:
Offline F17BAD
« Reply #36 on: 13 January 2012, 17:58 »
thanks dan :smiley:
a bit more than that haha
as for cable, try a mk2 1.3 cable
Offline Dan_GTi8v
« Reply #37 on: 20 January 2012, 12:32 »
thanks dan :smiley:
theres a ce2 wiring loom conversion guide on clubgti. Its for a mk2 ce2 fusebox but its the same fusebox as the mk3 and theres plenty of info in the thread relating to mk3s
http://www.clubgti.com/forum/showthread.php?t=205887
There are also people around who can do it for around £100 if you provide the looms, rubjonny did mine and a very good job it was too, that guys a legend :afro:
Offline dub-gti
« Reply #38 on: 20 January 2012, 23:12 »
so on that list all i need is the stuff with out the 16v beside?
so in essence every thing engine and engine wiring wise from a 1.8t,
was thinking of buying a 1.8t that had been crashed, but not sure the average price for a cat c/d
Offline Dan_GTi8v
« Reply #39 on: 22 January 2012, 22:02 »
if you have a 16v then yeah you only need the 1.8t bits or the custom stuff, though its still a good idea to get some things like engine mounts new
